skunk 2 stage 2 cams untuned, good or bad idea?
Old Aug 8, 2006 | 01:54 PM
beaneg6's Avatar
Default skunk 2 stage 2 cams untuned, good or bad idea?
here is the setup,
100% stock jdm type r bottom end
fully built portflow gsr head w/ skunk 2 manifold
290 or 310 cc injectors(not sure yet)
would this setup run decent untuned or is it a waste of time? i know that max power wont be acheived w/o a tune.
Old Aug 8, 2006 | 02:12 PM
DJ_NeX's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (beaneg6)
not only will max power probably not be achieved w/o a tune, but max reliability probably won't be achieved either. Although, you're running a fairly safe setup, I'd say as long as your valvetrain can take it, run it with the 310cc injectors and you'll be a happy lil wanka.
Old Aug 8, 2006 | 06:06 PM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_NeX &raquo;</TD></TR><TR><TD CLASS="quote">not only will max power probably not be achieved w/o a tune, but max reliability probably won't be achieved either. Although, you're running a fairly safe setup, I'd say as long as your valvetrain can take it, run it with the 310cc injectors and you'll be a happy lil wanka.</TD></TR></TABLE>
What is the point of building a engine if you're not going to tune it?
Old Aug 8, 2006 | 06:42 PM
boosted k20's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (mar778c)
what ecu will u be using. if VTEC is set lower than 5.4K then the car might bog out when VTEC engages
Old Aug 8, 2006 | 06:58 PM
beaneg6's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">what ecu will u be using. if VTEC is set lower than 5.4K then the car might bog out when VTEC engages</TD></TR></TABLE>
chipped p28...vtec @ 5200 no redline
Old Aug 9, 2006 | 07:59 AM
beaneg6's Avatar
Old Aug 9, 2006 | 08:03 AM
EG type GTR
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">no redline</TD></TR></TABLE>
Old Aug 9, 2006 | 08:08 AM
beaneg6's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (EG type GTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG type GTR &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i know...but he will be shifting @ about 8400
Old Aug 9, 2006 | 08:12 AM
EG type GTR
Guest
Posts: n/a
yeah i know...but he will be shifting @ about 8400</TD></TR></TABLE>
misshift = bye bye
Old Aug 9, 2006 | 08:28 AM
beaneg6's Avatar
misshift = bye bye</TD></TR></TABLE>
true but this is not my motor....so idc
Old Aug 9, 2006 | 08:31 AM
EG type GTR
Guest
Posts: n/a
true but this is not my motor....so idc</TD></TR></TABLE>
lol good answer. no redline = cool factor
Old Aug 9, 2006 | 03:41 PM
98vtec's Avatar
moderator emeritus
waste of a good motor if its not tuned. You spend all that money and cant spend another 400-500 for tuning.
Old Aug 9, 2006 | 05:28 PM
hybridmiklo's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (98vtec)
At first I thought you were just going to drive around from work and back with those cams untuned. BUt then reading on, I see you are going to try to race people with stage 2 cams untuned? Instantly I had a visual of this situation, and here is a picture that best describes it. . . .
Go spend some money for tuning.
Old Aug 9, 2006 | 05:38 PM
beaneg6's Avatar
Default Re: skunk 2 stage 2 cams untuned, good or bad idea? (hybridmiklo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote">At first I thought you were just going to drive around from work and back with those cams untuned. BUt then reading on, I see you are going to try to race people with stage 2 cams untuned? Instantly I had a visual of this situation, and here is a picture that best describes it. . . .
Go spend some money for tuning.</TD></TR></TABLE>
who said anything about racing? nowhere in this thread does it say that i am going to be racing...can you read? i was simply wondering if i put all this together can i drive on it for a while, then once the money is there...get it tuned! thanks
Old Aug 9, 2006 | 05:53 PM
fmrprojects's Avatar
when i put together my ls vtec with blox st 2 cams. i drove 400 miles to break it in and had no problems. just tune it asap and dont rip on it untuned
Old Aug 9, 2006 | 05:56 PM
JDM KaKa's Avatar
importbuilders has a good read on this topic
SpoonCivicSir20
Oct 23, 2009 01:59 PM
digital sol
Jul 7, 2008 07:44 PM
c1_sleeper
13
Jan 17, 2007 04:36 PM
BukakkEK9
Nov 3, 2006 07:31 PM
ff terror
Mar 22, 2005 11:19 PM
