Q: i see grease everywhere on my passenger side near axle/tranny . what is it.?
well own a 95 acura integra RS with a b20/lshead turbo. i see grease coming out from somewhere on my passenger side where axle/tranny is.. jacked up my car.. didnt see a torn cv boot.. so dont know what this grease is coming from.. cleaned it, drove it, then few days later see grease coming back.. its annoying and getting all over my samco radiator hoses and practically everywhere on my passenger side. Help please? I have no ABS if that does anything for information.
*EDIT UPDATE PICS:
Modified by Jesse. at 12:39 PM 8/9/2006
*EDIT UPDATE PICS:
Is it thick grease? Then its the axles, they dont have to be ripped to leak, the rubber gets soft and leaks from the seams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">Is it thick grease? Then its the axles, they dont have to be ripped to leak, the rubber gets soft and leaks from the seams.</TD></TR></TABLE>
ic.. yeah ur right can be.. grease is somewhat thick?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civiccoupe »</TD></TR><TR><TD CLASS="quote">dose your car click when you turn?</TD></TR></TABLE>
not when i turn but when im like on a hill , not moved and i turn my wheel all the way i hear noise.. maybe my car too low ( lowered all the way in frnts on megan racing suspension )..
Grease from the axles is a greenish/tan color and is very thick. Tranny fluid and oil are both more watery and by the time it dries up will be a black sludge.
I think it is coming out of the boot too. Sounds like as it rotates it is seeping out and being flung everywhere. The only thing I can think of is to get some plastic wrap used for food and wrap it around the boot then drive on the freeway a bit and then see if any comes out of the boot. This would eliminate the boots and help you look elsewere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">Grease from the axles is a greenish/tan color and is very thick. Tranny fluid and oil are both more watery and by the time it dries up will be a black sludge.</TD></TR></TABLE>
hmm looks like black grey lil melted chocolated look like (but its black / grey ) and near the bottom its like sludgey..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinai »</TD></TR><TR><TD CLASS="quote">I think it is coming out of the boot too. Sounds like as it rotates it is seeping out and being flung everywhere. The only thing I can think of is to get some plastic wrap used for food and wrap it around the boot then drive on the freeway a bit and then see if any comes out of the boot. This would eliminate the boots and help you look elsewere</TD></TR></TABLE>
ic.. ill try that.
ill also try to post pics of what the grease looks like. cause right now im also have a motor problem http://hondamarketplace.com/zerothread?id=1657134 . soo it might be something with that??
ic.. ill try that.
maybe dried up oil pan gasket leak?
haha dried up oil?? its the axles, if its clickin when you turn then your cv boot is riped and need to replace that **** 225$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrfrancisco »</TD></TR><TR><TD CLASS="quote">haha dried up oil?? its the axles, if its clickin when you turn then your cv boot is riped and need to replace that **** 225$</TD></TR></TABLE>
hahaha anybody that pays that much to have a cv boot replaced is a dumbass.
doesn't look like grease to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. »</TD></TR><TR><TD CLASS="quote">
second image looks like the boot is soaked in oil. maybe tranny fluid is leaking somewhere..?
</TD></TR></TABLE>second image looks like the boot is soaked in oil. maybe tranny fluid is leaking somewhere..?
[QUOTE=Jesse.]well own a 95 acura integra RS with a b20/lshead turbo. i see grease coming out from somewhere on my passenger side where axle/tranny is.. jacked up my car.. didnt see a torn cv boot.. so dont know what this grease is coming from.. cleaned it, drove it, then few days later see grease coming back.. its annoying and getting all over my samco radiator hoses and practically everywhere on my passenger side. Help please? I have no ABS if that does anything for information. [QUOTE]
off topic but u do know b20 and ls share the same head right? and yes i know except for the p8r. jus thought id fill u in if u didnt know.
then again, first image looks like grease could be building up around where that kink is in the boot.. i'd check that little dent in the rubber to make sure there isnt a puncture or something..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">Thats axle grease.</TD></TR></TABLE>
So skunked, does anything else in the engine bay take grease like that?
I mean, it seems like there aren't too many other options to pick from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
I mean, it seems like there aren't too many other options to pick from.</TD></TR></TABLE>
Not unless your playing with yourself and drop a load
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">Not unless your playing with yourself and drop a load
Okay, now you're just complicating things
</TD></TR></TABLE>Okay, now you're just complicating things
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ?? »</TD></TR><TR><TD CLASS="quote">
yeah i do, just sayin i have an LS Head instead of B20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrfrancisco »</TD></TR><TR><TD CLASS="quote">maybe dried up oil pan gasket leak?
dang 225.. more like 40$ from autozone! axle replace core exchange
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HGZ. »</TD></TR><TR><TD CLASS="quote">doesn't look like grease to me.
second image looks like the boot is soaked in oil. maybe tranny fluid is leaking somewhere..?</TD></TR></TABLE>
hmm ill jack up my car again and check, last time i was at work, it was on lifts and i didnt see any tranny damamge / leak.. didnt see any cv boot greease leak either.. it recently started happening after i lowerd my car all the way.
x10 million
x10 million
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">
x10 million</TD></TR></TABLE>
x5+7
x5+7
It's ******* axle grease, you can see it splattering all over and coming out of the boot in the pics.
Don't over think a simple problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">Squared
Square root??
:edit:
ZOMG page 2 ownage .. this calls for a random piczorss
</TD></TR></TABLE>Square root??
:edit:
