JDM ITR SUSPENSION!NEED HELP AND ADVICE!!
Hello I have a question about ITR suspension.(BTW the suspension is JDM) I know this guy that is welling to sell me front and rears springs and shocks (including)with the ITR lower control arms for the rears. My question is I drive a 95 integra limited edition would it make a differences if the suspension is jdm or it being ITR and from being from japan? My other question How could I know or tell if the suspension is really from A JDM ITR or both from japan and taken from a ITR ?Thank you for all your time and I deeply appreciate your advice!!
ALSO- the Front forks and brake lines are not included
could i just use this from my old ls suspension?
JDM/USDM is the same. The only thing that is different on the suspension component is if you get the 5lug conversion from a JDM ITR... the hub and axles are 36mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONISHIMA »</TD></TR><TR><TD CLASS="quote">
Yes, you can just swap them over.
As in suspension you mean the brakes also right? Well if they're JDM then you will also need the JDM ITR axles which like DC4KID said is 36mm, and ur usdm one is 32mm. And with all those you cant swap it over. Good luck.
And forks and brake lines are the same.
stock sus. sucks not worth buying unless your getting the 5 lug but it sounds like your doing just springs and struts jdm and usdm are basicly the same
i suggest just get aftermarket and use only the itr rear lca looks better and easier to remove and install
i-VTEC_do_you
Sep 5, 2006 06:07 AM
marko_think
May 13, 2004 06:35 AM
