DIY: Fix Your Broken Lip...
Old Aug 8, 2006 | 11:10 AM
Tuesdaynightfever's Avatar
Default DIY: Fix Your Broken Lip...
Alright guys, I tried searching and couldn't really find anything on how to fix a cracked lip. I figured I would make a mini DIY for anyone who is interested. I would first like to say that I am not good at these so don't expect a masterpiece here, this is simply to help some people out and give a bit more detail than most of the previous threads I have read on this. I used this method to repair my ABS plastic front lip that was SNAPPED COMPLETELY IN HALF. When I started this "project" my lip was two completely seperate pieces.
Materials needed:
PVC Pipe Adhesive (comes in a can similar to rubber cement)
60 Grit Sandpaper
100 Grit Sandpaper
1000 Grit wet/dry Sandpaper
Primer
Paint of choice
Steps used to repair broken lip:
First, clean the lip at the cracked or damaged area.
Second, apply the PVC Pipe Adhesive to the cracked area of the lip and push together tightly and hold for approx. 60 seconds.
After it is dried (I would suggest letting it sit 10 minutes or so just to make sure) paint thin layers of the PVC Pipe Adhesive to the cracked area of the lip. I loaded it on the inside of the lip because when bolted up this won't even be seen, but on the outside I did light layers until the crack was covered up.
Then, sand using 60, 100, 1000 grit sandpaper.
Finally, primer and paint the lip your color of choice.
Now for pictures of the finished product:
Remember, my lip was two seperate pieces when I started. Snapped completely in half. The pictures don't really do it justice but they are something to give you an idea of what it looks like now. I assure you in person you can not even tell that the lip has had any type of damage done to it. If you have any further questions please feel free to ask!
P.S. This isn't a thread asking for opinions of the front lip, so please no flames
Enjoy
Old Aug 8, 2006 | 11:29 AM
52 views and not a single comment
Well, at least I'm happy with it, haha.
Old Aug 8, 2006 | 11:44 AM
DAsix's Avatar
The before pics would help a little.
Old Aug 8, 2006 | 11:48 AM
ekcivic9's Avatar
Default Re: (DAsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsix &raquo;</TD></TR><TR><TD CLASS="quote">The before pics would help a little.</TD></TR></TABLE>
Old Aug 8, 2006 | 11:50 AM
Hahah, I know. I didn't think it was going to turn out near this nice so I didn't think about taking them. Just imagine the lip snapped completely in half...
Old Feb 6, 2007 | 08:27 AM
karkrazy9's Avatar
Default Re: (Tuesdaynightfever)
so is the adhesive ava. anywhere like hard ware stores and auto part stores? cause i have this samelip broken and would like to fix it.
Old Feb 6, 2007 | 08:34 AM
Nate047's Avatar
Default Re: (karkrazy9)
some before pix would help... and some pix durring the process...
Old Feb 6, 2007 | 10:33 AM
Markland Photo's Avatar
where was it snapped before hand?
Old Feb 6, 2007 | 10:34 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: (Nate047)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate047 &raquo;</TD></TR><TR><TD CLASS="quote">some before pix would help... and some pix durring the process... </TD></TR></TABLE>
Old Apr 11, 2007 | 05:04 PM
nahledge's Avatar
Nice write up. Good thing i havent had that problem with my polyurethane lip.
Old Apr 11, 2007 | 08:37 PM
grjp1988's Avatar
my itr is crack and nice writeup will try it.
Old Apr 11, 2007 | 08:44 PM
EJ8 944's Avatar
damn i have an oem si lip i've been trying to repair, i used plastic bond but one of the cracks just cracked again, i may need to try this out.
have to tried putting some stress on it, like bending and twisting it a little to see if it is as strong as it was before?
Old Apr 13, 2007 | 04:28 PM
EJ8 944's Avatar
bump for some answers
Old Apr 13, 2007 | 04:55 PM
my lip was in 3 pieces and had a hole
and i used masking tape and resprayed it, holding up just fine hah
Old Apr 28, 2007 | 05:02 AM
Mhollaek9's Avatar
Default Re: (bulletspastsunset)
NICE RIGHT UP LAST NITE AFTER BACKING OUT MY DRIVEWAY I WAS TOO CLOSE TO THE CURB AND THE LEFT SIDE OF MY LIP WAS HANGING OFF CRAZY GLUED THAT BITCH AND NOW ITS OK BUT I DONT THINK ITS GONNA HOLD FOR TOO LONG
Old Apr 28, 2007 | 05:05 AM
what gsr's Avatar
Default Re: (Mhollaek9)
OK COOL!
Old Apr 28, 2007 | 06:58 AM
PhoKYU!'s Avatar
Default Re: (what gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what gsr &raquo;</TD></TR><TR><TD CLASS="quote">OK COOL! </TD></TR></TABLE>
lol
nice write up
Old Apr 28, 2007 | 07:18 AM
siblues's Avatar
Default Re: (So-Lo.w!)
Nice job but was your crack a clean break or was it missing little pieces?
Old Apr 28, 2007 | 09:21 PM
Mhollaek9's Avatar
This happened to me last night as I was coming out my driveway
Basically the lip broke off the bracket and my friend said once it breaks its a wrap but I would like to think otherwise with your expertice guys thanks
sk8shorty012
Feb 6, 2006 06:06 PM
EJ1_519
Sep 16, 2005 06:37 AM
Italiano 2KGS
Apr 29, 2004 10:33 AM
GSR2001
Mar 22, 2002 05:28 AM
