PM6 with d15b2 motor, will it make a difference?
Old Aug 8, 2006 | 10:33 AM
nk2k2's Avatar
Default PM6 with d15b2 motor, will it make a difference?
just like title says, will it make a huge difference? i know that 95% of you are going to say do the mpfi swap then its going to be a huge difference but can i jsut use a PM6 ecu on my stock d15b2 w/o problems? i know that the rpm limit is going to change but what else?
Old Aug 8, 2006 | 10:36 AM
ludesrv's Avatar
You will have problems. MPFI ecus don't like DPFI.
Old Aug 8, 2006 | 10:39 AM
nk2k2's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">You will have problems. MPFI ecus don't like DPFI.</TD></TR></TABLE>
well how come spoon sports says it works in this thread?
https://honda-tech.com/zerothread/1715087
Old Aug 8, 2006 | 10:42 AM
ludesrv's Avatar
Default Re: (4g4d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread/1715087</TD></TR></TABLE>
The ecu, to run properly, needs 4 injectors and a resistor box and a different dizzy.
Whatever man, plug one in and try it...it's your car, not mine. I do things the right way.
Old Aug 8, 2006 | 10:45 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (4g4d)
I think he was reffering to a MPFI-swapped d15b2..
If you hook up a MPFI ecu on a DPFI car,
It will run like absolute crap and
the check engine light will come on..
Old Aug 8, 2006 | 10:47 AM
nk2k2's Avatar
Default Re: (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">I think he was reffering to a MPFI-swapped d15b2..
the check engine light will come on..</TD></TR></TABLE>
good to know. dude props to you for helping out the EF board.
Old Aug 8, 2006 | 10:55 AM
88DXCRX's Avatar
Default Re: (4g4d)
Sure man..
PS&gt;I tried this once just to see what would happen...
The results are posted above...
It did actually run,but I seriously doubt
it would have even been driveable,
much less made an improvement of any sort..
Old Aug 8, 2006 | 12:29 PM
ludesrv's Avatar
Sure, when I say it won't work, it's not good enough.
But wait, spoon sport said it was ok... .
Old Aug 8, 2006 | 01:36 PM
E_F_9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Sure, when I say it won't work, it's not good enough.
But wait, spoon sport said it was ok... .</TD></TR></TABLE>
nk2k2's Avatar
no dude. dont get me wrong. i never doubted you. i just wanted to make sure because what spoon sports said wasnt totally complete so i wanted to make sure then 88DXCRX confirmed it. sorry if i was misunderstood.
hondachris1994
Mar 2, 2006 12:33 PM
BMcivic
49
Mar 1, 2004 01:41 AM
civicsir.com
11
Feb 7, 2004 10:09 AM
Hatchtrap
Sep 14, 2003 09:28 PM
Trellis
May 22, 2003 12:44 PM
