JDM b18c 99' type r Swap
I have a 99' JDM Type R swap for sale, it is a 98 spec Type R. It came out of my friends hatch he had to sell. The transmission was just rebuilt, it has the 4.785 final drive.
Asking: $3500 as is
Unfortunately it does not have the red valve cover. However, it does have an 8lb flywheel and ACT heavy duty clutch.
Feel free to call or post any questions,
760-553-5969 or 714-702-4008
Modified by b16pro at 12:34 PM 8/11/2006
Modified by b16pro at 12:37 PM 8/11/2006
Modified by b16pro at 12:45 PM 8/11/2006
Please BUMP after viewing....thanks!
Modified by b16pro at 5:40 PM 8/23/2006
Modified by b16pro at 3:17 PM 8/29/2006
Modified by b16pro at 10:57 PM 10/25/2006
Asking: $3500 as is
that was the case that was used for the transmission when it was rebuilt because the diff had blown up
Modified by b16pro at 1:39 PM 8/29/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">sound fishy
sounds????????? it even looks fishy i see pry marks where the vin should be .. even if you just switched cases why would you remove the vin? either way i wouldnt buy it because if you get stopped and a cop sees the tamper marks you car will be impounded if the cop wants to be a dick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">sounds????????? it even looks fishy i see pry marks where the vin should be .. even if you just switched cases why would you remove the vin? either way i wouldnt buy it because if you get stopped and a cop sees the tamper marks you car will be impounded if the cop wants to be a dick </TD></TR></TABLE>
i didnt switched the cases it was already like that i think the diff blew up because it had brand new synchros and the diff had brand new bearings.
Modified by b16pro at 11:20 PM 10/25/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuKThEiVeS »</TD></TR><TR><TD CLASS="quote">i was going to buy it too, but it does look kinna fishy </TD></TR></TABLE>
yea i was gona buy it too
TeaAddict
Sep 13, 2005 10:25 AM
