GSR to EK Civic Ebrake cable question
I have recently finished my rear disc swap. I put 2000 GSR rear trailing arms on my 99 civic ex. The ebrake cable on the passanger side is a good inch or two shorter than the drivers side. Luckily, I have a set of cables from a 99 civic si from a damaged set of trailing arms -- But does anyone know if swapping these out will solve my problem. If so, should I swap the driver's side or passangers side?
Thanks guys
Thanks guys
take out the longer one and compare it to the 99 si ones.
if its the same size/shorter, swap out both, if its longer, swap out only that one
msinsky14
Jun 24, 2007 08:15 AM
JLEK
17
Jun 11, 2007 09:58 PM
scoobyghost
Jun 4, 2003 04:15 PM
