Suspension & Brakes Theory, alignment, spring rates....
boingy boingy. rear suspenion is bouncy
Old Aug 8, 2006 | 08:11 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default boingy boingy. rear suspenion is bouncy
Okay i feel like tiger for whinnie the poo.. I installed the omni full coil over over the past week. The front is perfect not bouncy at all. but the rear bounces constantly. if i go over a speed bumb it will bounce at least 3 times. Is there anything I could do to reduce the bouncyness. I searched the problem and some people suggested looseing the spring to give more travel and give a better ride. Or should i stiffen the springs?
Old Aug 8, 2006 | 10:41 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: boingy boingy. rear suspenion is bouncy (littleblue)
Vehicle's year, make, model, and kind of spring and shock combo do you have?
Old Aug 8, 2006 | 02:19 PM
littleblue's Avatar
Default Re: boingy boingy. rear suspenion is bouncy (ScareyH22A)
1993 civic dx omni full coil-over. I took the tensoin off the springs a bit and it helped alot. im wondering if i should do it some more.
Old Aug 8, 2006 | 03:13 PM
_BEN_'s Avatar
Do you have allot of weight over your back wheels? Speaker box?
Old Aug 8, 2006 | 03:26 PM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleblue &raquo;</TD></TR><TR><TD CLASS="quote">1993 civic dx omni full coil-over. I took the tensoin off the springs a bit and it helped alot. im wondering if i should do it some more.</TD></TR></TABLE>
By "tension", I'm assuming you mean that you've dropped the perch down by twisting it. If you relieve the sprung weight of vehicle by lifting it on a jack, and drop the perch just enough until your spring starts to loosen up under the upper spring seat, that's the most "tension" relief you can do to make a difference.
Sounds like you don't have enough damping on the shock for the high spring rate.
Old Aug 8, 2006 | 08:58 PM
littleblue's Avatar
Default Re: boingy boingy. rear suspenion is bouncy (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Do you have allot of weight over your back wheels? Speaker box? </TD></TR></TABLE>
Yes i have a speaker box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">By "tension", I'm assuming you mean that you've dropped the perch down by twisting it. If you relieve the sprung weight of vehicle by lifting it on a jack, and drop the perch just enough until your spring starts to loosen up under the upper spring seat, that's the most "tension" relief you can do to make a difference.
Sounds like you don't have enough damping on the shock for the high spring rate.</TD></TR></TABLE>
But.. isnt omni supposed make sure the rate and dampering is right to give the best ride? and not be bouncy. I guess I should just drop the bottom perch more. or take out the speaker box cause i dont need bass.
Old Aug 8, 2006 | 10:30 PM
FalkenSiR's Avatar
I know it may sound stupid, but did you by any godly chance install your rear lca's upside down?
Old Aug 9, 2006 | 01:44 AM
bad-monkey's Avatar
it sounds like you could have had an issue with coil-bind, which is when the spring can't compress anymore when the suspension compresses. lowering the perch would help prevent that, but it's not going to get progressively better as you drop the perch more.
Old Aug 9, 2006 | 09:52 AM
littleblue's Avatar
Default Re: boingy boingy. rear suspenion is bouncy (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">I know it may sound stupid, but did you by any godly chance install your rear lca's upside down? </TD></TR></TABLE> lol no i didnt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you could have had an issue with coil-bind, which is when the spring can't compress anymore when the suspension compresses. lowering the perch would help prevent that, but it's not going to get progressively better as you drop the perch more.</TD></TR></TABLE>
I will lower the perch some more today. but its so hard to get the jack under my car
Makavelidadawn
Honda Civic (2006 - 2015)
Mar 21, 2010 11:13 PM
maynards_ek
Nov 17, 2007 12:37 PM
Redsun
Suspension & Brakes
May 10, 2006 04:20 PM
blkgsr03
10
Nov 23, 2003 04:54 PM
Jaker
Jul 27, 2003 07:59 AM
