F20B & H22 Valves
Old Aug 8, 2006 | 07:33 AM
SiR-T's Avatar
Default F20B & H22 Valves
can anyone tell me if the valves on the H22 are the same as the f20B valves? Sizing, clearances etc.
matt
Old Aug 8, 2006 | 07:35 AM
2point2's Avatar
Default Re: F20B & H22 Valves (SiR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR-T &raquo;</TD></TR><TR><TD CLASS="quote">can anyone tell me if the valves on the H22 are the same as the f20B valves? Sizing, clearances etc.
matt </TD></TR></TABLE>
good question. Ask the prelude or allmotor guys.
Old Aug 8, 2006 | 07:42 AM
ludesrv's Avatar
Default Re: F20B & H22 Valves (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
good question. Ask the prelude or allmotor guys.</TD></TR></TABLE>
Haha. Why ask such a question in a CRX forum?
Old Aug 8, 2006 | 08:36 AM
SiR-T's Avatar
Default Re: F20B & H22 Valves (ludesrv)
yea i'll check the prelude section reason i ask is because alot of ppl are swapping to these engines so i wanted to get an idea from anyone here
Old Aug 8, 2006 | 08:37 AM
SVOboy's Avatar
Do a parts number search.
Old Aug 8, 2006 | 08:55 AM
2point2's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Do a parts number search.</TD></TR></TABLE>
If you can find part #'s for an F20B I'll fly to where you are and shake your hand.
Old Aug 8, 2006 | 09:07 AM
SVOboy's Avatar
Just call up europe,
Old Aug 8, 2006 | 09:08 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Just call up europe, </TD></TR></TABLE>
"no speaka da ing-ga-lish"
Old Aug 8, 2006 | 09:11 AM
SVOboy's Avatar
Yeah, I forgot the f20b was the euro sirII or whatev when I posted.
Old Aug 8, 2006 | 12:24 PM
charlee's Avatar
pardon my ignorance. but what is the BIG difference between the engines? there almost identical.
Old Aug 8, 2006 | 01:13 PM
SVOboy's Avatar
I'm pretty sure a good analogy would be d15b vtec to d16z6.
Old Aug 8, 2006 | 01:26 PM
lightcrx's Avatar
i remember reading the f20b valves are smaller than the h22.
ill look for it
-joseph
edit i found it
Quote, originally posted by PirateMcFred »
Oh you lucky bastard. Then I would recommend giving it a try and post pics and dyno plots. But I would definiately check for clearance. I would hazard a guess that since the F20B head is very similar to the H22 that you should not have any problems. Now I would just worry about spinning a 95mm crank to 7500 or more...
oh wait. i forgot that the F20 valves are smaller so the piston valve reliefs might be a little on the small side for the H22 valves but you can probably enlarge them. Just make sure you clay it to check clearance.
the Pirate
heres thee topic
https://honda-tech.com/zero...91591
Old Aug 8, 2006 | 01:48 PM
2point2's Avatar
There is A LOT of hardcore info on the H22 in the prelude section.. the FAQ is really good.
Old Aug 8, 2006 | 02:06 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: (2point2)
I read they worked swapable...from f20 to h22 head satan ran them I believe I read...and they were pure **** and dropped 3 of them seperate times...weak point? who knows....
miked123
Jun 11, 2013 03:01 PM
nitroeg
Nov 14, 2005 06:59 PM
2001accord
Apr 5, 2005 11:08 PM
951dc5
Jan 2, 2005 03:03 PM
