Removing pins from ECU clips B and C?
im in the middle of doing a dpfi- mpfi b16 swap and im having the hardest time figureing out how too remove the pins from clips B and C. is there some trick to it? clip A is simple with an eyeglass screwdriver.
i pulled out the white plastic inserts on the back of clip B yet they still wont budge, how do i loosen them?
https://honda-tech.com/zerothread?id=1191491
I found it was easier if I sharpened the eyeglass screwdriver (shave metal off the flat sides). Its a bitch.
seanb18c1
Sep 10, 2003 10:20 PM
91hondacrx
Mar 4, 2003 01:43 PM
