Tail light swap
Old Aug 8, 2006 | 07:17 AM
gigigirrl's Avatar
Default Tail light swap
I have a Honda Civic 2000. I just purchased a tail light assembly here http://shorl.com/fimogupufrady it is the #11-5277-01 which is the correct tail light 4 d sedan outer passenger. But there were no installation instructions. What is the procedure for removing the tail light assembly?- we have already removed the nuts from the bolts.
gigigirrl
Old Aug 8, 2006 | 07:58 AM
BlueIntegraBoy's Avatar
Default Re: Tail light swap (gigigirrl)
Remove the nuts, remove the bulb sockets, remove the old tail light, installation is in reverse.
Old Aug 8, 2006 | 08:10 AM
Jokerluv's Avatar
yes basically taking aprt and put back together
Old Aug 8, 2006 | 08:49 AM
Syndacate's Avatar
on the flipside of ur trunk are nuts that go on bolts that come out of the light housings through holes in the trunk into the trunk...you take off those nuts, and unplug the bulbs from the housings, and the light just comes right off
if I remember correctly there's like 4 on the inside one and 3 on the outside one
Daryl Reyes
Jan 12, 2016 03:34 PM
marcus81184
Mar 18, 2009 05:02 PM
Shintakun
Honda Civic (2001 - 2005)
Nov 5, 2008 11:25 PM
mech101
Oct 5, 2008 12:58 PM
