Rear LCA's: Are they hard to remove?
Old Aug 8, 2006 | 07:06 AM
TURBO DC2's Avatar
Default Rear LCA's: Are they hard to remove?
Well as we all know how the rear lower control arm bolt connected to the shock fork is almost always ceased on our integras. Well I wanted to know how hard it is to remove the LCA's altogether? I got a set of extra LCA's, so I plan on swapping those in with my new OMNI coilovers on my daily driver teg. So I dont have to deal with torching out the bushings and getting new ones ($$$$)
Theres 2 bolts on the LCA, do these come out easy? Or are they just as hard to take out... Never had to do this before.
Thanks in advance
pic of a lower control arm to give you an idea, not mine:
Old Aug 8, 2006 | 07:13 AM
be.twenty's Avatar
there's actually three bolts on the LCA .. and the one that connects the shock is usually the one to seize.... other than that, a good impact will get them out.. i've removed all three with a 250lb impact no problem
Old Aug 8, 2006 | 07:16 AM
IHTFP's Avatar
Default Re: Rear LCA's: Are they hard to remove? (TURBO DC2)
they are hard to remove if the bolts are seized, as youve already noted...
so pray for loose bolts or bust out the sawzaw
Old Aug 8, 2006 | 07:23 AM
TURBO DC2's Avatar
Default Re: (Nuck Chorris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuck Chorris &raquo;</TD></TR><TR><TD CLASS="quote">there's actually three bolts on the LCA .. and the one that connects the shock is usually the one to seize.... other than that, a good impact will get them out.. i've removed all three with a 250lb impact no problem</TD></TR></TABLE>
Ya there's 3 bolts. But what I meant is that I'm not going to touch the one that bolts to the shock/spring because it is ceased. I want to take out the LCA along with the shock assembly as one unit. So therefore I only have to deal with the 2 bolts. So my question is how hard are those bolts to take out
Old Aug 8, 2006 | 07:28 AM
PrinceAli132's Avatar
Default Re: (TURBO DC2)
IF you have access to air tools, it won't be hard at all. If not, they might give you a little trouble, but nothing a good size breaker bar can't handle. Also spray some PB Blaster on there to help loosen some of the grim on there.
Ali
Old Aug 8, 2006 | 07:40 AM
iH8RICERZ's Avatar
Default Re: (PrinceAli132)
breaker bar should do it.... I just took mine off last weekend. Those ssr lca's look sexy though!
Old Aug 8, 2006 | 08:05 AM
BlueIntegraBoy's Avatar
Never had a problem removing mine. I didn't have pneumatic tools, just a breaker bar.
Old Aug 8, 2006 | 08:12 AM
be.twenty's Avatar
yeah breaker bar will work on the other two no problem...
Old Aug 8, 2006 | 10:02 AM
playahwitgame's Avatar
whats the advantage of aftermarket lca's?
Old Aug 8, 2006 | 11:50 AM
Tim.'s Avatar
I did the same thing on my 99 teg a few weeks ago. Bought aftermarket LCA's thinking i was avioding the trouble bolts, just like you did. This didn't work for me at all. Both sides' outer LCA bolts were seized, and one inner LCA bolt was. All in all, to install my rear suspention, I had a total of 6 seazed bolts. And I thought it was bad on my old civic that had 2 seized rear LCA bolts... :/
Not saying this will happen to you, but be prepared for it to happen.
Old Aug 8, 2006 | 11:52 AM
Tim.'s Avatar
Default Re: (playahwitgame)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playahwitgame &raquo;</TD></TR><TR><TD CLASS="quote">whats the advantage of aftermarket lca's?</TD></TR></TABLE>
Weight reduction, bling, avoiding terrible bolts.
Old Aug 8, 2006 | 12:04 PM
Vitesse's Avatar
Default Re: (spoon0313)
Just don't snap the head off any old bolt's..
I torched the bolt lightly to warm it up so some liquid wrench could thread itself down with the change in temp. let it sit for about 1/2 hour and the f.cking head snapped off, it was amillino degrees out and Ihadn't eaten all day.. oh it was the last bolt too.. probably the most unenjoyable experiences of my life.
Old Aug 8, 2006 | 12:06 PM
madredintegra's Avatar
A few months ago I did the whole coilover/Omni LCA's install on my 99 LS and all three bolts in both control arms were seized. I ended up snapping the heads off of several of the bolts...then torched out the rest. It turned out to be a 2 day installation...not fun
Old Aug 8, 2006 | 12:13 PM
Vitesse's Avatar
Default Re: (madredintegra)
Yea I was using a bushing puller for my trailing arms' and removing the 5 bolts so I can let the arm hang down. Sucks.. it's totally expectable though.
Old Aug 8, 2006 | 09:45 PM
94rs-turbo's Avatar
u have itr lca's on there? and yeah 3 bolts plus the 2-3-4 i dunno i dont have abs but take off the abs line
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:52 AM
jash
16
Jul 12, 2010 03:55 AM
mymomsdrunk
Mar 5, 2008 08:38 AM
stumpyf4
Aug 29, 2002 05:29 PM
a1k0n
12
Mar 26, 2002 07:00 AM
