zc-vtec question
hey guys, next week i will be swapping a ZC into my crx and throwing on my current z6 head on it and im wondering which head gasket will i need? also do i have to get the head resurfaced?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec »</TD></TR><TR><TD CLASS="quote">hey guys, next week i will be swapping a ZC into my crx and throwing on my current z6 head on it and im wondering which head gasket will i need? also do i have to get the head resurfaced?</TD></TR></TABLE>
get the Z6 metal headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec »</TD></TR><TR><TD CLASS="quote">bump: which timing belt do i use with this combo?</TD></TR></TABLE>
The Y8/Z6 belt works fine but its very very tight,,the 92-95 dx belt also works and is better imo..
also dont forget to remove the oil jet from the block otherwise you'll have no vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">get the Z6 metal headgasket
also dont forget to remove the oil jet from the block otherwise you'll have no vtec</TD></TR></TABLE>
thanks for the input... how would i remove the oil jet from the block?
thanks for the input... how would i remove the oil jet from the block?</TD></TR></TABLE>
you take a screw that fits,, then screw it into the jet and pull it out with some vice grips
you know where the jet is ? or do you need a picture?
edit- just check out this thread,it has pics https://honda-tech.com/zerothread?id=554053
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec »</TD></TR><TR><TD CLASS="quote">the sohc zc...</TD></TR></TABLE>
That answers my question and the stuff that's been posted in generally right. You're just making a mini-me. Do you understand why I asked? There's like 10+ different "ZC" motors out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec »</TD></TR><TR><TD CLASS="quote">the dohc u cant swap heads on</TD></TR></TABLE>
Really? Thanks for the tip.
Actually, if you want to split hairs...the 1st gen guys have figured out how to do it with their engines (with the caveat that its sooo not worth the trouble)
Really? Thanks for the tip.Actually, if you want to split hairs...the 1st gen guys have figured out how to do it with their engines (with the caveat that its sooo not worth the trouble)
hatchback19
Feb 29, 2004 10:56 AM
