DOHC ZC - How much compression should I have
Old Aug 7, 2006 | 09:47 PM
91civicshaw's Avatar
Default DOHC ZC - How much compression should I have
almost seems like this engine isn't making as much power as it should. How much compression should I have and would getting my Stock si ecu reprogrammed help that much?
Old Aug 7, 2006 | 10:20 PM
janz3n's Avatar
Default Re: DOHC ZC - How much compression should I have (91civicshaw)
im not an expert but around 150 should be good or a little higher. did you do a compression test already? if not do one and show the numbers. and i think if you chip your ecu you'll just run really rich and wouldnt be worth it.. by what iv read chipping is mainly for turbos.
Old Aug 8, 2006 | 06:39 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicshaw &raquo;</TD></TR><TR><TD CLASS="quote">almost seems like this engine isn't making as much power as it should. How much compression should I have and would getting my Stock si ecu reprogrammed help that much?</TD></TR></TABLE>
compression on a new DOHC ZC would be 190 with minimum of 135 - since you are at altitude of 5000-6000ft. it is going to be a lot less - around 155 would be very good - also, due to the altitude, the horsepower is going to be about 18-20% less than it would be at sea level - we have same problem here in Colorado at about the same altitude - get a PG7 ECU
messeduprex
Jun 28, 2004 10:52 AM
ek_99_SiR
Mar 1, 2004 04:28 PM
blah13
Jun 8, 2003 08:18 AM
