Stuff I still need to get rid of - - >
Old Apr 24, 2002 | 12:11 PM
TurboT's Avatar
Default Stuff I still need to get rid of - - >
-Built 1997 GSR block, Golden Eagle Manufacturing sleeved GSR block, Bored 85mm cylinders, Jet washed block, Stepped deck cylinder for better gasket mating, JE 85mm 10.5:1 compression pistons, JE XC rings, Crower forged rods, New Honda bearings, Blueprinted, new ITR oil pump, ITR oil pan, new oil pick up, new seals and gaskets, Cometic 85mm head gasket 0.060" thick, GSR water pump, ITR timing belt, 0 miles, just built $3000
-ITR intake camshaft, 18k miles $175
-STR race silver cam gears, used very little, never slipped $150
-ITR valve cover, cut for cam gear access, paint near the bolt down posts on the side of the timing belt wore off, the valve cover was touched up. $60
-RevHard non-ac iron manifold, flanged for 35mm wastegate $350
-2 1/2" Drag GEN 3 downpipe with 3" extension $150
-3" Flexpipe, brand new $50
-Climax blue anodized fuel rail, 3/8" NPT on both ends, does not work with stock FPR $50
-K&N -6 both ends, billet aluminum fuel filter, ss mesh filter $30
-Paxton Signature fuel filter, excellent condition $30
-Paxton signature series fuel pressure regulator $75
-Z10 civics and integras traction bar setup, brand new $310
-Front and rear VIS coilovers mounted on four KYB AGX shocks, fits integras, used for 7k miles, fully assembled, includes pillow mounts $300
-Apexi Power FC ECU and Apexi Power FC handheld commander, brand new condition, in original box $900
-MSD Digital 6 plus, excellent condition
-MSD HVC coil, excellent condition
-MSD b18c5, b18c1, b16a2 distributor cap, excellent condition
-Clifford Inteliguard alarm, 600IQ, 2 key fobs, wiring, box, everything included $100
-DEI remote window roll up and roll down control, brand new $75
-Greddy 60mm white A/F gauge with peak/hold, brand new $220
-NOS 100-PSI fuel pressure gauge $5
-Wings West W-type kit, needs painting, melted around the exhaust tip area, needs to be plated after being painted $225
-Del Sol seats with gray stripe mounted to GSR brackets, excellent condition $300 pick up only
-1998 GSR alternator, excellent condition $50
-2000 b16a2 valve springs and retainers, full set $40
-1998 b18c1 valve springs and retainers, full set $40
-1998 GSR upper timing belt cover, cut for cam gears $5
-1998 GSR distributor with cap, excellent condition $250
-1998 GSR intake manifold, new condition $60
-1998 GSR IAC valve, excellent condition $40
-1998 GSR IAT valve, excellent condition $20
-1998 GSR power steering pump, excellent condition $30
-2000 GSR power steering pump, new condition $35
-2000 GSR power steering reservoir, new condition $15
-1998 GSR power steering hose, excellent condition $10
-2000 GSR left/right front brakes, excellent condition $60
-1998 GSR a/c compressor, excellent condition $50
-1997 GSR a/c condenser, excellent condition $50
-2000 GSR a/c lines, new condition
-1998 GSR spark plug wires, new condition $20
-2000 B16a2 camshafts, new condition $60
-2000 GSR power steering rack, new condition $75
-1998 GSR dash good for projects, e-mail me $125
-1998 GSR purge valve, excellent condition $20
-1998 A/C mounting bracket and driver side torque mount, , excellent condition $50
-1998 power steering engine mounts, excellent condition $40
-1998 alternator mounts, excellent condition $50
-1998 Acura Integra stock hood, excellent condition $150 pick up only
-1998 Acura stock amber front turn lights, excellent condition $20
-Earls -10 straight fittings
-Earls -10 90 degree fittings
-Earls -10 120 degree fittings
-Earls -10 to 1/2" NPT steel fittings, straight, 45, and 90 angles
-Earls -10 to 3/8" NPT aluminum fittings, straight, 45, and 90 angles
-Earls -10 to -10 fittings
-Earls -10 to -8 fittings
-Earls -8 straight fittings
-Earls -8 45 degree fittings
-Earls -8 90 degree fittings
-Earls -8 120 degree fittings
-Earls -8 to -8 fittings
-Earls -8 to 1/2" NPT aluminum fittings, straight, 45, and 90 angles
-Earls -8 to 3/8" NPT aluminum fittings, straight, 45, and 90 angles
-Earls -8 to 3/8" NPT with 1/8" NPT gauge port
-Earls -6 straight fittings
-Earls -6 45 degree fittings
-Earls -6 90 degree fittings
-Earls -6 to 1/4" NPT aluminum fitting
-Earls -6 to 3/8" NPT aluminum fitting
-Earls -6 and -8 bulkhead fittings
-Earls -10 plugs
-Earls -6 Teflon braided hose
-Earls -8 Perfomo-flex hose
-Earls -6 Teflon steel hose ends, straight, 45, and 90 degree angles
let me know what you need on the fittings, or else it goes on egay.
[Modified by TurboT, 2:09 PM 4/24/2002]
[Modified by TurboT, 9:59 AM 4/26/2002]
Old Apr 24, 2002 | 02:01 PM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (TurboT)
Old Apr 24, 2002 | 07:31 PM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (AkumaY)
1/8" NPT
Old Apr 24, 2002 | 07:37 PM
jetli6969's Avatar
New User
can i get just the front torque mount? if so email at jetli6969@aol.com
Old Apr 24, 2002 | 07:46 PM
1.8EG-T's Avatar
Default Re: Stuff I still need to get rid of - - > (jetli6969)
To the guy with a closet full of parts.
Old Apr 24, 2002 | 09:59 PM
pagong's Avatar
Terry your Clifford Intelliguard alarm...i went to dei's site and i cant find the 600iq...is this an old model? what are the features...?
Old Apr 25, 2002 | 05:54 AM
TurboT's Avatar
which side?
Old Apr 25, 2002 | 05:55 AM
TurboT's Avatar
liquid filled? if so ill take it
i don't think it is....
not 100%, my memory is failing me
Old Apr 25, 2002 | 05:57 AM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (pagong)
yep, it's like 3-4 years old...
the remotes are practically brand new..
actually, everything in the box for this alarm is close to brand new...
i don't think DEI would have any info on the 600IQ...
did you try a search on google or something?
Old Apr 25, 2002 | 06:25 AM
Big Teggie's Avatar
What year is the itr intake cam?
Old Apr 25, 2002 | 06:53 AM
Mr. Vapor's Avatar
Default Re: Stuff I still need to get rid of - - > (Big Teggie)
hey terry,
didnt forget about ya. If i send out that check today, for that wastegate vac fitting (90 Degree barbed 1/8th NPT) is it possible i can get it by friday (the 3rd) it will be in the mail tommorow, so you should get it by saturday.
let me know
Tim
Old Apr 25, 2002 | 09:03 AM
turboteg96's Avatar
can you send me some pics of the exhaust manifold. gagnon.irg@forces.ca
Old Apr 25, 2002 | 09:22 AM
TurboT's Avatar
from a 97 itr
Old Apr 25, 2002 | 09:24 AM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (NYb16)
hey terry,
let me know
Tim
hm... by tomorrow?
he... next day shipping?
e-mail me...
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (turboteg96)
got your e-mail, i'm taking pics tomorrow or sat...
Old Apr 25, 2002 | 12:18 PM
00TurboEX's Avatar
could you email me info about the 3" flexpipe? maybe a pic or at least the length. i am very interested and have cash. thanks xtreme199@aol.com
david
Old Apr 25, 2002 | 02:11 PM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (00TurboEX)
david
sent you mail
Old Apr 26, 2002 | 08:59 AM
TurboT's Avatar
ttt
Old Apr 26, 2002 | 09:28 AM
jdm_latino's Avatar
what does that include?
Old Apr 26, 2002 | 09:55 AM
EVO 5's Avatar
Default Re: Stuff I still need to get rid of - - > (jdm_latino)
are you willing to part out the kyb agx shocks? would they fit on a 92-95 civic hatch? what car, year, and model did these shocks came out of? how much would you want for them shipped? let me know. thanks.
Old Apr 26, 2002 | 09:59 AM
turbo_ef9's Avatar
give me pics of the fpr and the digital 6, coil, and cap.. hit me up aights.. thanks
Old Apr 26, 2002 | 01:01 PM
Smurfylude's Avatar
For the laundry list of parts....
How much for the Paxton fuel filter???
Old Apr 26, 2002 | 07:55 PM
TurboT's Avatar
Default Re: Stuff I still need to get rid of - - > (Sushi X)
Old Apr 27, 2002 | 08:46 PM
B18C-RnVA's Avatar
New User
ttt
Old Apr 27, 2002 | 11:08 PM
ITRinEJ1's Avatar
Default Re: Stuff I still need to get rid of - - > (B18C-RnVA)
