water in my intake help
Old Aug 7, 2006 | 08:32 PM
importtuner07's Avatar
Default water in my intake help
ok saturday i had to take my girl to work because her mom was out somewhere and it was rainin. So i jus let it coast through the puddles and rev afterwards jus incase any water had gotten sucked in well im taken the back roads to get her to work an there is a puddle that doesn look to deep i do the same thing coast through but there was a pot hole and my intake sucked up a lot of water my car starts bogging down i get outta the water try revin but it dies. i take off my intake clean out my throttle body and start it takes a few trys but it starts and then since then been not idealin right popin outta the exhaust. so any sugetions thanks my car is a 1994 Honda Civic Ex B16a
Old Aug 7, 2006 | 09:04 PM
BOOSTED RIVAL's Avatar
Default Re: water in my intake help (importtuner07)
Blend rods, try taking your spark plugs out and crank the motor and see if there water in the cylinder.
Old Aug 7, 2006 | 10:53 PM
H-adict's Avatar
agreed!...water does not compress like air does!
Old Aug 7, 2006 | 10:59 PM
IT'S ME DAVID's Avatar
NooB
Default Re: water in my intake help (H-adict)
your luck it still starts and runs.it could have gotten hydrolocked.thats when water gets sucked into the intake mostly caused by cold air intakes.when it gets hydrolocked the cars motor is gone trashed.
Old Aug 8, 2006 | 05:04 AM
Default Re: water in my intake help (IT'S ME DAVID)
one of my friends was saying to take out the spark plugs and put b12 in the cylinders then let it sit for an hour. Then try to crank it have any of you heard of b12 and i think i will replace my plugs also.
Old Aug 8, 2006 | 06:12 AM
92redhatch's Avatar
bro take out your plugs and crank the motor before you hydrolock your motor. Its very simple. And it will solve your problem. Make sure to soak up the water with a rag.
RaDs330
Jan 19, 2010 08:42 PM
2000h22a
Jun 15, 2008 06:45 AM
K20Death
Apr 30, 2006 02:25 PM
bman511
Apr 1, 2005 08:03 PM
animated_life
Feb 23, 2003 04:51 PM
