main bearing colors traslate to part numbers?
see link below...
http://www.acuraparts247.com/p...ch=no
all the bearings are listed as a,b,c,d,e,f,g blah blah etc. but the charts all go by colors...so does anyone know how the colors translate into the letters?
please help!
please help!
run by your local acura dealer parts dept. there parts catalog shows the colors just have them print out a list of all bearings part numbers it should show the color or call them and tell them you need to get the price of a bearing (the color you need) and then ask them for the part number ... they should give it to you
The lower the last digit in the first segment of numbers, the thicker the bearing (blu). I believe a 7 is a pink.
sounds good but now im even more confused...they have bearings listed as upper, and lower which i understand but then there are ones that arent designated but are the same price...so confused...i cant keep ordering the wrong ****.
ok this should help a little to confuse you more or clear things up
now u need the same amount upper and lower .. you cant use a all upper or all lower ...the color should be the same for your set up ... now the acura parts has two diff part numbers for all the bearings because there two diff makers of the bearing but they are the same bearing ....just pick one just make sure your using the right color ... these two links should help ....
http://importsource.net/~ssr/bearings2.pdf <---- Main Bearings
http://importsource.net/~ssr/bearings1.pdf <--- Rod Bearings
now u need the same amount upper and lower .. you cant use a all upper or all lower ...the color should be the same for your set up ... now the acura parts has two diff part numbers for all the bearings because there two diff makers of the bearing but they are the same bearing ....just pick one just make sure your using the right color ... these two links should help ....http://importsource.net/~ssr/bearings2.pdf <---- Main Bearings
yeah i understand how to pick colors but i am looking for how they translate to the acurap art numbers os i can order them...my local dealer is an idiot and can do nothing witohut part numbers.
rice a roni
Apr 6, 2008 11:37 AM
yaoming315
Jul 21, 2007 11:46 PM
