Cylinder head fell from about 4 feet on its corner... pics here
Old Aug 7, 2006 | 05:42 PM
baonest's Avatar
Default Cylinder head fell from about 4 feet on its corner... pics here
well i had it on some rubbermaid plastic storage containers, and the bottom one gave way and the cylinder head slid off and crashed to the ground . well i was suprised with the damage, but it doesnt look half bad. i just dont want to spend the time to get it repaired because this is the same head i have been trying to sell.
kinda ticks me off now that i have to lower the price big time...
how much damage is this. i think its not bad because its where the seal goes...
Old Aug 7, 2006 | 05:46 PM
Dave_B's Avatar
Sorry for the misfortune. Really sucks to hear, but me personally... I'd never use that head again. Would make a nice centerpiece on a coffee table or something though.
Old Aug 7, 2006 | 05:54 PM
Rene M's Avatar
Default Re: (Dave_B)
I just im'd you, i did one very much like that and it is still on a track car today..
Old Aug 7, 2006 | 05:55 PM
Dave_B's Avatar
Rene, what did you do to fix that kind of damage?
Old Aug 7, 2006 | 06:00 PM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Rene, what did you do to fix that kind of damage?</TD></TR></TABLE>
If it were me:
I would use a file on the flat cap bearing surface to see how flat that area is and get it true.
re tap or heli coil the bolt hole.
and use a lot bit of Honda bond to stop the oil leak your going to get....
That is the dead end for the cam so the cam does not ride on the surface " thank god "
Just the cam plug goes there. The biggest battle will be to get the cam bearing cap back on flat and with the correct crush not to be to tight or loose. Then to get a good torque on those " easy to break bolts".
Plastiguage the cam for sure!!!!!!!!!!
Old Aug 7, 2006 | 06:33 PM
Circuit Star-29's Avatar
Default Re: (Rene M)
EEK....Aluminum... I would def. have it mag'd.
Old Aug 7, 2006 | 06:59 PM
Aquafina's Avatar
Default Re: (Circuit Star-29)
Weld that **** up and take it to a machine shop.
Old Aug 7, 2006 | 07:13 PM
Dave_B's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Weld that **** up and take it to a machine shop.</TD></TR></TABLE>
It's aluminum, it's not that easy.
Old Aug 7, 2006 | 07:27 PM
Mythias's Avatar
Default Re: Cylinder head fell from about 4 feet on its corner... pics here (baonest)
PM sent.. I have a spare head.
Old Aug 7, 2006 | 08:11 PM
Aquafina's Avatar
Heat it up so it doesn't bleed and weld it. Pretty easy.
Old Aug 8, 2006 | 04:41 AM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">EEK....Aluminum... I would def. have it mag'd.</TD></TR></TABLE>
right......
Old Aug 8, 2006 | 04:51 AM
junkyard racer's Avatar
Default Re: (D)
JB weld.
Old Aug 8, 2006 | 08:44 AM
Rene M's Avatar
How do you plan to do that? Aluminium can not be magnafluxed its not a magnetic metal?
Old Aug 8, 2006 | 09:08 AM
d16dcoe45's Avatar
I don't know about that one. To pay to have it welded and remachined might be more than the bare casting is worth. You could try welding it yourself if you have some experience welding aluminum castings, as it is quite a bit different than welding steel. I am sure damage worse than that has been repaired succesfully though--especially for a one off race head off an important vintage racer or something along those lines.....
Old Aug 8, 2006 | 09:34 AM
Ed 341's Avatar
Old Aug 8, 2006 | 10:01 AM
FowaDoorsOfFury's Avatar
invest in engine stand maybe?
Old Aug 8, 2006 | 11:15 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (FowaDoorsOfFury)
HTF would an engine stand help a head not fall out of a box it's in?
Old Aug 8, 2006 | 11:24 AM
itr1244's Avatar
Default Re: (Stinkycheezmonky)
ouch
Old Aug 8, 2006 | 11:49 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FowaDoorsOfFury &raquo;</TD></TR><TR><TD CLASS="quote">invest in engine stand maybe?</TD></TR></TABLE>
what in the hell is up with all these new people recently that can't read?
Old Aug 8, 2006 | 02:09 PM
Opie's Avatar
Just blow on it and brush it off, it's fine
Old Aug 8, 2006 | 02:14 PM
baonest's Avatar
Default Re: (Opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie &raquo;</TD></TR><TR><TD CLASS="quote">Just blow on it and brush it off, it's fine </TD></TR></TABLE>
hah, a little oil leak never hurt no body.
i dont know if i wanna put time into it. i dont have any time until after sept. 8th, so if i can sell it i will. this was an extra head i had laying around
Old Aug 8, 2006 | 03:10 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the misfortune. Really sucks to hear, but me personally... I'd never use that head again. Would make a nice centerpiece on a coffee table or something though. </TD></TR></TABLE>
yeah, i wanted to do that with my friends darton sleeved 2.0L ls/vtec block after he sent a eagle rod thru the bottom of the block, and have it cleaned and and lay a peice of glass over it
Old Aug 9, 2006 | 03:52 AM
baonest's Avatar
Default Re: (98ekhx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ekhx &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i wanted to do that with my friends darton sleeved 2.0L ls/vtec block after he sent a eagle rod thru the bottom of the block, and have it cleaned and and lay a peice of glass over it </TD></TR></TABLE>
i did that with my 2.0L block. those squishy coozy things fit perfect in them. perhaps i may just put a slab of glass on it.
Old Aug 9, 2006 | 05:37 AM
ITRnorway's Avatar
a little of topic: does the 2 liter ls/vtec blocks suck? should i stay away from them?
Old Aug 9, 2006 | 07:01 AM
Suspetise...
Default Re: (CRXnorway)
Search for B20/VTEC or variations of that for more information than you can read in a day. There are issues with stock B20 sleeves apparently, is what it comes down to.
