Rear brake conversion
Old Aug 7, 2006 | 05:23 PM
90jdmcrxdude's Avatar
Default Rear brake conversion
I have a 90 CRX DX and am planning on doing the rear disk swap, I'm gonna go get the stuff this weekend, and I just wana know exactly what I have to get. Just let me know everything.
Old Aug 7, 2006 | 05:52 PM
VtecSyndrome's Avatar
Default Re: Rear brake conversion (90jdmcrxdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmcrxdude &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 CRX DX and am planning on doing the rear disk swap, I'm gonna go get the stuff this weekend, and I just wana know exactly what I have to get. Just let me know everything.</TD></TR></TABLE>
the "search" function holds all the info you desire
Old Aug 7, 2006 | 05:55 PM
Default Re: Rear brake conversion (VtecSyndrome)
Way to be an *** and waste space. If you dont know then just dont write anything.
Old Aug 7, 2006 | 06:02 PM
mahatma's Avatar
You rival John Edwards for biggest douche of the universe
And you still need to take the words "using" and "having sex with" out of your sig, in order for it to make sense
Old Aug 7, 2006 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmcrxdude &raquo;</TD></TR><TR><TD CLASS="quote">Way to be an *** and waste space. If you dont know then just dont write anything.</TD></TR></TABLE>
I was being nice, I am suprised nobody flamed you yet for asking a question that has been SOO talked about that your post actually did not need to be posted at all. Your post was actually a waste of space in the first place, if you seriously search then you will find all the info you need. and I do know what you need as I have done it before but now you definetely gotta search and find it yourself
George Knighton's Avatar
H-T Order of Merit
Default Re: Rear brake conversion (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">You rival John Edwards for biggest douche of the universe</TD></TR></TABLE>
At least he doesn't call himself Mahatma.
Old Aug 7, 2006 | 06:10 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Rear brake conversion (George Knighton)
I'm not an EF expert, but i can lend some advice.
You will need (i think) a rear disc brake setup from any 88-91 Civic/CRX or 90-93 integra. This should bolt up if you have the trailing arms and all.
Someone correct me if im wrong.
Old Aug 7, 2006 | 06:13 PM
Default Re: Rear brake conversion (JDM_Ej)
yeah I did search, but I found all different stuff, and I was just wondering if you get the stuff from a 91 CRX SI can you just use all of that, or do you need to get some stuff from the teg. exactly everything you need from exactly what cars
Old Aug 7, 2006 | 07:11 PM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">At least he doesn't call himself Mahatma.</TD></TR></TABLE>
you mock gandhi?
Old Aug 7, 2006 | 08:58 PM
Old Renegade's Avatar
90-93 complete rear disc with e-brake cables. do not use the upper and lower control arms from the teg use the ones from the ef, better geometry. optional but well worth it a mster polyeurathane bushing kit, if not at least the rear trailing arm bushing in polyeurathane. highly recomended, is to get the proportioning valve, master cylinder and booster from the 90-93 teg with rear disc of course. do not get one from a teg that has a.b.s. this will gives you better pedal pressure and you well stop on a dime. trust me i have a rear disc conversion on my 91 ef. for a plus you can get some steel braided brake lines and now will be a great time to upgrade your brake fluid. i use valvoline synthetic. hope this helps, good luck..
Old Aug 8, 2006 | 03:40 PM
Default Re: (Old Renegade)
Thanks that helps somebody actually isnt an *** out there
Old Aug 8, 2006 | 03:45 PM
DEEGORILLA06's Avatar
old renegade is right....couldnt be said better.....hey post pic of when your done....
Old Aug 8, 2006 | 04:39 PM
silentdork818's Avatar
Default Re: (DEEGORILLA06)
The Integra e-brake cables are a little bit long...theyll work fine but if you can find the CRX Si cables get them.
Old Aug 8, 2006 | 04:47 PM
Lil Red CRXsi's Avatar
Default Re: (silentdork818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">The Integra e-brake cables are a little bit long...theyll work fine but if you can find the CRX Si cables get them.</TD></TR></TABLE>
Exactly,get the E-brake cables for a 91CRXsi from the dealer,problem solved.
Old Aug 8, 2006 | 04:49 PM
92integra_gs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Renegade &raquo;</TD></TR><TR><TD CLASS="quote">90-93 complete rear disc with e-brake cables. do not use the upper and lower control arms from the teg use the ones from the ef, better geometry. optional but well worth it a mster polyeurathane bushing kit, if not at least the rear trailing arm bushing in polyeurathane. highly recomended, is to get the proportioning valve, master cylinder and booster from the 90-93 teg with rear disc of course. do not get one from a teg that has a.b.s. this will gives you better pedal pressure and you well stop on a dime. trust me i have a rear disc conversion on my 91 ef. for a plus you can get some steel braided brake lines and now will be a great time to upgrade your brake fluid. i use valvoline synthetic. hope this helps, good luck..</TD></TR></TABLE>
Old Aug 9, 2006 | 02:42 AM
Default Re: (90jdmcrxdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmcrxdude &raquo;</TD></TR><TR><TD CLASS="quote">Thanks that helps somebody actually isnt an *** out there</TD></TR></TABLE>
glad to be able to help hope your project turns out great. reppin da EF FOREVA!!!
Old Aug 9, 2006 | 09:49 AM
civicandy's Avatar
Default Re: (Lil Red CRXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Red CRXsi &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly,get the E-brake cables for a 91CRXsi from the dealer,problem solved.</TD></TR></TABLE>
unless you get them for $10 at a junkyard. then just secure them properly and enjoy the good brakes. this is a great swap, but i recommend the poly bushing swap at the same time. you can use the upper/lower arms from the teg, but your rear tires might rub. i think the geometry is the same, but the track width is 1/2" wider.
Old Aug 10, 2006 | 04:47 PM
Default Re: (civicandy)
unless you get them for $10 at a junkyard. then just secure them properly and enjoy the good brakes. this is a great swap, but i recommend the poly bushing swap at the same time. you can use the upper/lower arms from the teg, but your rear tires might rub. i think the geometry is the same, but the track width is 1/2" wider. [/QUOTE]
so why use them and run the chance of having you tire rub, why not just keep the ef geometry by using what it came with from the factory?
Old Aug 11, 2006 | 05:11 AM
civicandy's Avatar
i did use the ef upper/lower control arms, front and rear. i was just pointing out the fact that you can use the da stuff.
Old May 2, 2009 | 07:41 PM
crazyB-junkie's Avatar
New User
if i use skunk2 lower control arms for 89 crx i dont know wether u can specify ef or usdm is it gonna make a difference
Old May 2, 2009 | 08:35 PM
EFinawesomeman's Avatar
Yes it will make a difference. You need to cut a EF in half horizontally and do the same to yours weld the two together and then you can use your Skunk2 blower control arms so your car can be 3 times faster around a corner.
Old May 2, 2009 | 10:08 PM
Cnile1's Avatar
no comment
Old May 2, 2009 | 10:20 PM
mitsubishiv5's Avatar
you can get either 90-93 integra DA lower trailing arms or 93-up integra both models gsr and LS. you can also run the abs type trailing arms just take off the abs sensors(im running a 1997 integra gsr disk brake conversion with abs deleted.)
you will need :
trailing arms with hub assembly
toe alignment bars (sedans MUST use the sedan toe alignment)
camber alignment etc
ebrake cables (DA, DC)(sedans must use DA sedan ebrake cables.)
very straight forward easy job and might as well get the 4040 prop valve while your at it.
i have an extra set of gsr ebrake cables
Old May 7, 2009 | 12:54 PM
superhatchbackbros's Avatar
sorry to bust in on this thread! but i was wondering if u could use the 94 and up teggy rear disc? if so id like to know bc i can get a whole setup off the teggy at my local junkyard!
Old May 7, 2009 | 01:35 PM
4drEF's Avatar
Keyboard Humorist
Why is this thread not locked?
Search
FAQ
