FS: Brand New NIB Eagle 95mm stroker crank
In an standard b18 block you could use a b16 rod with this crank, but with a standard 1.181 compression height piston you would only have .005" deck clearance, stock is around .02.
Just out of curiosity, why is that? Forgive me if I'm just thinking too simple, but if the LS/B20 has an 89mm stroke and 137mm rod, and your crank has a 6mm longer total stroke (3mm @ TDC) and 134mm B16 rods shouldn't it pretty much balance each other out?
I'm going off standard listed measurements on eagle's site.
stroke/2+rod length-deck ht=0 deck compression height-stock comp ht=deck clearance
3.74/2+5.29-8.346=1.186-1.181=.005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">Perhaps an issue remedied by a little bit thicker headgasket?</TD></TR></TABLE>
yeah, that or a piston with the pin moved up slightly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">Brand New NIB Eagle 95mm stroker crank normal weight. 3.74" stroke. Works with proper rods/pistons in both b18 blocks and tall deck. I can come up with pics, but please, dont we all know what a crank shaft looks like? Paid around 600 with shipping for this, but have decided to go a different route. Please make a reasonable offer.
thanks,
Jared</TD></TR></TABLE>
tell me about it, this guy asked for pics of stock gsr cams, then after i gave him the pic, he said "how do i know those are real gsr cams?" wtf, like why would anyone lie about some stock parts like they are special or anything. Anyways free bump for you.
thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY »</TD></TR><TR><TD CLASS="quote">
thanks!!
</TD></TR></TABLE>thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320DRAGWORKX »</TD></TR><TR><TD CLASS="quote">pm you good ****</TD></TR></TABLE>
I returned your pm but never heard anything else.
who wants this?
