RSX and ITR rear hubs
Correct me if im wrong here...
Are the RSX and ITR rear hubs the same? They look very similar. Are they interchangeable? Anybody know the differences between them?
thanks,
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 »</TD></TR><TR><TD CLASS="quote">Part numbers are different and looking at the catalog it would seem to me that they are infact, different.</TD></TR></TABLE>
They look similar - do you know how they are different? Do RSX hubs fit on a GSR/LS style spindle?
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 »</TD></TR><TR><TD CLASS="quote">No, they dun fit. THe ITR hub will fit the ls/gsr spindle as the trailing arm is the same.</TD></TR></TABLE>
Well GSR/LS/ITR trailing arms are the same, however the ITR spindle is like ~10mm longer - so you cant really put a ITR hub on a GSR spindle - unless you do some machine work. You cant tighten down the nut.
I have a bad rear hub, and they are uber expensive from honda wanted to see if i could use a RSX since they are easy to find. Guess not. saaddd...
What about 97+ preludes? Do they have the same hubs?
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 »</TD></TR><TR><TD CLASS="quote">DC2 Integra trailing arms are the exact same....IIRC.</TD></TR></TABLE>
They are, but the spindles are different. And you cant order the spindles separately from honda - they come already pressed into the trailing arm. So you gotta buy the whole thing.
but ya, prelude hub and itr hub? same? different?
liam
liam
DC5AM
Nov 22, 2006 08:28 PM
