bushings and cliper kit
Old Apr 24, 2002 | 11:16 AM
EliteIntegra's Avatar
Default bushings and cliper kit
im lowering my car with HR racing ... i had sugggestions that i need new bushing and a caliper kit or was it a clamper kit.. i cant pronounce it,., can someon educate me on this topic please
Old Apr 24, 2002 | 11:23 AM
BROOD's Avatar
Default Re: bushings and cliper kit (EliteIntegra)
I think you mean new bushings and a "camber" kit. The camber kit will compensate for the negative camber that occurs with lowering your car a decent amount. Alot of negative camber can cause accelerated inner tire wear.
The bushings was probably suggested incase the original bushings are worn out.
Hope that helps clear things up a bit?
Old Apr 24, 2002 | 05:51 PM
Default Re: bushings and cliper kit (SLPR)
thanks slpr since im just lowering my car.. are replacing the bushings and camper kit nessessary though.... ? i dont wanan get scamed by my mechanic if he says i HAVE to get ti casue the camper kits expensive i here
Old Apr 25, 2002 | 04:18 PM
mdpalmer's Avatar
I have my car lowered with a camber kit. For some reason, it squeaks like crazy in the front right. I've been told it's either the bushings or the camber kit, or a combo of both. What do you think? Should I replace the bushings?
Old Apr 29, 2002 | 10:32 AM
Default Re: bushings and cliper kit (mdpalmer)
i had to replce my bushings i didnt have a choice... the prev owner of the car didnt rust proof so it was rusted solid... and they needed to replce the bushings... they arent expensive.... like 50-60 canadian dollars
jchrm80
Oct 4, 2007 06:32 PM
95slomocivi
Feb 23, 2006 03:48 PM
Flux
May 30, 2003 12:47 PM
Jolf
Feb 14, 2003 04:16 PM
