brake light and srs light...
Old Aug 7, 2006 | 01:25 PM
mmmtrbolude93's Avatar
Default brake and srs indicator lights...
My brake indicator light has been on for about 3 weeks and all of my brake lights are all working properly... Why is it doing this?
ALso I had to remove my blown airbags and the srs light is on of course... how do I get rid of that light? I already tried removing the fuses..
Old Aug 7, 2006 | 02:06 PM
helicopter201's Avatar
Default Re: brake and srs indicator lights... (mmmtrbolude93)
check your grounds, one is in the trunk in the very middle right below the u latch. might need cleaning. for the airbag i think you would need to have honda replace airbags which costs alot. they probly reflash the ecu cel codes. i had the srs light come on when i forgot to release ebrake and drove for 3 blocks. went away after turning off the engine and restarting. anyyyywayyy...
Old Aug 8, 2006 | 05:47 AM
yeah for new airbags and labor try 3000 dollars... that is why they totaled my car but I decided to keep it and go with no airbags for now
Old Aug 8, 2006 | 06:20 AM
TurboBA8's Avatar
Default Re: (mmmtrbolude93)
check your brake fluid as well.
Old Aug 8, 2006 | 07:39 AM
Default Re: (TurboBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboBA8 &raquo;</TD></TR><TR><TD CLASS="quote">check your brake fluid as well. </TD></TR></TABLE>
no nono.. sorry if I misled but it is the BRAKE LAMP indicator not the brake indicator.
for the srs I think I am just going to cut the wire to the light so it will go off but I will try the deal with the ground wire for the brake lamp
Old Aug 8, 2006 | 07:56 AM
HeatherJ's Avatar
My brake lamp indicator stays on frequently too, doesn't matter if the ebrake is on or down, I was told that it wasn't a problem and I don't think you can fix it by taking out the fuse, doesn't that just cut all the power to the dash lights?
Old Aug 8, 2006 | 08:02 AM
Hawkze_2.3's Avatar
Low brake fluid will also trip the brake light.
Old Aug 8, 2006 | 08:06 AM
crdcz03's Avatar
Fortune Cookie Member
my brake lamp light has been on for like a year
for once id like to have a dash that doesnt light up like a christmas tree as i drive down the road
Old Aug 8, 2006 | 08:08 AM
i hate the way it looks... it just pisses me off
Old Aug 8, 2006 | 09:16 AM
crdcz03's Avatar
i dunno about yours but mine only comes on after i hit the brakes for the first time after i start the car, then it stays on till i turn the car off.
Old Aug 8, 2006 | 02:55 PM
Default Re: (crdcz03)
are you sure both of your brake lights come on when the brake lamp light comes on? im pretty much about to kill someone with my drivers side brake lamp. it will go off at random times and stayed on for quite a while until i cleaned the trunk brake light ground. now it only comes on once every 2 days or so for about 3 min then goes off. ticks me off really much. i know from the haynes manual that there is another brake light ground inside the chassis by the center console i think it was. haven't gotten a chance to check it yet but hopefully that will fix the stupid light
btw dude sweet avatar you and JTCdudeman have the best ones on the site ^_^. is that your car or a takata ad?
Old Aug 8, 2006 | 04:05 PM
ECX's Avatar
ECX
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">
for once id like to have a dash that doesnt light up like a christmas tree as i drive down the road </TD></TR></TABLE>
lol, I bet that was distracting for awhile, and probably still is
Old Aug 8, 2006 | 04:30 PM
soundbomber's Avatar
Default Re: (ECX)
there's a service connector for the SRS system that you need to jump, but the process to get the code to clear is quite involved. do a search
97delslo
Jul 29, 2015 12:59 PM
kornkid21792
Jun 4, 2009 01:16 PM
DSMRacing
Mar 29, 2006 10:37 AM
Gsrteggrl
Jul 2, 2005 10:06 AM
BigZ88
Feb 21, 2005 09:17 PM
