IM GASKET
Old Aug 7, 2006 | 10:34 AM
RSXTYPES0818's Avatar
Default IM GASKET
DOES ANYBODY KNOW IF THE HONDATA IM GASKET DOES MAKE A DIFFERENCE AND HOW HARD IS IT TO PUT ON.
Old Aug 7, 2006 | 12:00 PM
ScuDC5's Avatar
dude, you gotta control that caps lock. Anyway, its simple to install with the right tools and the time. Just need to unbolt the top of the mani as well as the side bolts and you can kinda pry it apart a bit, take out the thin dinky gasket and slide in the Hondata IMG. Takes about a half hour to 45min.
It keeps the manifold very cool. If you try and touch it after idle for like 10min with OEM gasket you'll pull back with no skin on your fingertips. (or wrist like me). After the Hondata IMG gasket you can actually touch it (still hot so don't be dumb). But it drops the temp quite a bit giving you a more powerful feel and responce. It's a worthwhile investment.
Old Aug 7, 2006 | 12:44 PM
somebody was tellin me that u had to take one of the studs out of the block and u had to take the whole manifold off and i thought that the gasket went through the bolts so wouldnt u have to take the whole manifold off
sounds confusing srry
Old Aug 7, 2006 | 01:00 PM
06RSXS's Avatar
cooler IM gasket means better response. overall you'll get about a 3-5% increase in performance. hondata isn't the only maker of aftermarket MGs
EX-T
10
May 4, 2014 08:02 PM
roller3804
Oct 23, 2007 03:04 PM
M2B4
Oct 13, 2007 06:42 PM
BolivianFuego
Sep 11, 2006 09:01 PM
GSR4U2NV
11
May 22, 2005 08:04 PM
