Suspension & Brakes Theory, alignment, spring rates....
Caliper bolt Size...
Old Aug 7, 2006 | 10:31 AM
Jon V's Avatar
Default Caliper bolt Size...
Ok guys I'm doin a little brake upgrade on my EK and I am trying to figure out what size the original front caliper bolt size is...
My new TL "sports model" brakes have a bigger caliper bolt which i am also trying to find the size for.
I am at work right now and was going to have one of the machinst make me a stepped bit so I could drill out the knuckle today when I get home, and mount up the new brakes...
So I don't have eigther of the bolts with me and I can't seem to find the info on the net... I figured maybe I would give it a shot and see if any of you could help me out. If not I'll just have to take care of it tomorrow...
A little teaser...
Old Aug 7, 2006 | 10:36 AM
Tyson's Avatar
Default Re: Caliper bolt Size... (Jon V)
why dont you ask in the civic forum....
Old Aug 7, 2006 | 11:02 AM
Jon V's Avatar
Default Re: Caliper bolt Size... (Tyson)
civic/teg EG/EK
all same bolt...
I figured I might have better luck here...
Old Aug 7, 2006 | 11:23 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">civic/teg EG/EK
all same bolt...
I figured I might have better luck here...</TD></TR></TABLE>
'92-00 Civic/Del Sol
EG/EK Civics Discussion
really?
how about starting with which bolt youre even talking about.
Old Aug 7, 2006 | 12:50 PM
Jon V's Avatar
#14 caliper bolt...
I have a 5 lug swap on the car, but the knuckle is the same between all the civic/teg chassis... So the bolt size will be the same...
Also looking for the size of the #6 caliper bolt on the TL sport model brakes...
I can't believe they don't list the sizes on the site...
Looks like I'll be figuring it out tomorrow
Old Aug 7, 2006 | 07:07 PM
chrisw85's Avatar
youre converting from the civic's floating caliper to the radial fixed of the TL?
Old Aug 8, 2006 | 04:58 AM
Jon V's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">youre converting from the civic's floating caliper to the radial fixed of the TL?</TD></TR></TABLE>
yah... something I should know about that?
Modified by Jon V at 4:55 PM 8/8/2006
Old Oct 8, 2006 | 07:10 PM
BrakeExpert's Avatar
Default Re: (Jon V)
A guy named migs tried this and what he found that on an ITR, he had to tap the TL caliper and use "timeserts" and used a civic/integra caliper bolt (yes I'm refering to #18 on that civic brake caliper pic.) The civic bolt is a 17mm if that helps and is 12 x 1.25mm (torque to 80lb-ft.)
P.S. I don't believe the TL caliper is considered radially mounted, its just a fixed 4-piston brembo caliper (not the same as the RL caliper).
Old Jun 11, 2014 | 03:08 AM
livingcb919's Avatar
I am working on the front brake caliper of a 1990 acura integra. What size socket does the brake caliper bolt take?
Old Jun 11, 2014 | 04:18 AM
grumblemarc's Avatar
The Grumpiest
???? Do you not have a socket set or something? Common sizes are 12mm, 14mm, 17mm.
Old Jun 11, 2014 | 08:37 AM
veks's Avatar
serious? trial and error from one of your metric socket...
R-gonaut
Jun 5, 2011 07:27 PM
jake00si
Feb 20, 2010 09:47 PM
DC2 to AP2
Acura TL, RL & ZDX
Nov 19, 2005 06:37 PM
SGR Teg
Jan 29, 2003 06:53 AM
