camber settings
Old Aug 7, 2006 | 10:18 AM
Craigp23usa's Avatar
Default camber settings
i am getting new tires finally gs-d3's and am wondering what camber u would recomend using the H&R race springs, full es bushings (if it matters) sway bars (sus. tech) , strut bars on my 91 civic hatch.
this is a daily driver, toe will be set to factory settings. thanks
Old Aug 7, 2006 | 10:21 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: camber settings (Craigp23usa)
I don't know; maybe someone else here does. Or, better yet, you might get more expertise in the Suspension forum, if this is for street use, or the Road Racing forum, if it's for the track (since this forum is for wheels and tires).
Good choice on tires, BTW; buy by August 26 so you can get the $40 rebate...
Old Aug 7, 2006 | 10:26 AM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Craigp23usa &raquo;</TD></TR><TR><TD CLASS="quote">i am getting new tires finally gs-d3's and am wondering what camber u would recomend using the H&R race springs, full es bushings (if it matters) sway bars (sus. tech) , strut bars on my 91 civic hatch.
this is a daily driver, toe will be set to factory settings. thanks</TD></TR></TABLE>
My car sits about 2.5" lower than stock( about as low as your setup) and I run 1.5" neg. camber each side.
You're going to need a camber kit though, unless you want to run even more camber (2-3 degrees), and significantly reduce the life of your tires.
My advice: get a quality camber kit ( Skunk2) and a good alignment from a shop that can adjust camber kits.
chronodyne28
Oct 24, 2004 07:03 PM
CoxhEd
Jun 10, 2004 09:49 PM
Tad
Aug 26, 2003 12:13 PM
b16_madman
Jul 10, 2003 05:58 PM
HatchBox
12
Jan 14, 2003 09:15 PM
