taking rotor off gsr head
Old Aug 7, 2006 | 09:46 AM
T4HATCH's Avatar
Default taking rotor off gsr head
Hey i need to know how to take the rotor off (from the distrubutor), its seems kinda tricky. Are there any free service manuals or anything?
Old Aug 7, 2006 | 08:49 PM
Takumi Fujiwara's Avatar
Default Re: taking rotor off gsr head (T4HATCH)
If it's an OEM dizzy, it should have a screw on the shaft. Pull screw, and then pull the rotor off.
Old Aug 8, 2006 | 07:36 AM
SkankyEJ7's Avatar
Default Re: taking rotor off gsr head (Takumi Fujiwara)
be careful on theast screw they like to strip out, so use the right size screw driver
Old Aug 9, 2006 | 02:59 PM
CASTUDILLO01's Avatar
HELLO. EASY WAY TO REMOVE THE THE ROTOR IF YOUR REPLACING IT IS TO GET A BIG SET OF PLIERS AND BREAK IT OFF AND THEN REMOVE THE SCREW.
Old Aug 9, 2006 | 03:31 PM
maxspeedhonda's Avatar
Default Re: taking rotor off gsr head (CASTUDILLO01)
like stated above, don't strip it out.
An impact driver might help you if it is stuck (and probably will be)
Old Aug 11, 2006 | 10:52 PM
T4HATCH's Avatar
alright thanks guys got it out
Old Aug 12, 2006 | 08:32 AM
velocitytrends.com's Avatar
Default Re: taking rotor off gsr head (maxspeedhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxspeedhonda &raquo;</TD></TR><TR><TD CLASS="quote">like stated above, don't strip it out.
An impact driver might help you if it is stuck (and probably will be)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">HELLO. EASY WAY TO REMOVE THE THE ROTOR IF YOUR REPLACING IT IS TO GET A BIG SET OF PLIERS AND BREAK IT OFF AND THEN REMOVE THE SCREW.</TD></TR></TABLE>
smoovekriminal
Aug 17, 2007 05:03 PM
BringIT
Aug 12, 2007 09:31 PM
dcdcdc
Jul 2, 2006 10:18 AM
Flux
Apr 1, 2003 07:44 PM
SurferX
Jan 24, 2003 08:31 PM
