Strange electrical issue
Old Aug 7, 2006 | 09:42 AM
95ACEX's Avatar
Default Strange electrical issue
Hey everyone. I have a 95 Accord EX 4dr 5 Speed 2.2, and I've had a strange electrical problem for the past 5 months or so. I will list all of the details and symptoms that I can.
The battery light illuminates when the car is revved past 2.5-3k RPMS, and when this happens the lights dim and the subwoofer cuts out. If I drive underneath that rev range, everything is normal.
-Battery, connections, alternator all tested fine with my mechanic
-The alternator was replaced last fall (the only variable that was changed anywhere near the start of this issue)
-I have a stereo running off of the battery with an aftermarket brass connecting block. However, I have been running this stereo for almost 3 years with no problems.
-The problem only happens under load, not in neutral, and it is less pronounced when going downhill.
-It is intermittent...seems to go away when it rains (though not all the time)
-When I pull the stereo fuse, the problem still persists
This problem is driving me crazy, and I have a feeling the alternator I got (autozone refurb ) is bad. I'm wondering if any of you have any insight that I could be missing.
Thank you
Old Aug 7, 2006 | 12:34 PM
02 accord's Avatar
Default Re: Strange electrical issue (95ACEX)
Sounds like a bad alternator. Go back to autozone, and have them check it.
Old Aug 7, 2006 | 12:35 PM
SuperSlow's Avatar
check your grounds first.
Old Aug 7, 2006 | 07:20 PM
95ACEX's Avatar
Default Re: Strange electrical issue (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds first.</TD></TR></TABLE>
details on how to go about this?
Old Feb 18, 2013 | 06:05 PM
Chris Jimenez's Avatar
i have a 94 honda accord ex i recently installed a pioneer deh-p6600 after market stereo everything went in good and worked but then it started to cut out every now and then it like screetches and cuts out but well continu playing it does this every now and then not sure if its when i turn it up to loud or not im thinking it is but not sure it also somtime sounds like its laking power like it sounds good sometime then it sounds like its dull and quite i keep having to readjust it anyone no why this is i put a new wiring harness on the radio and in the car and also added a ground coming off the back of the stereo to the back stereo support brace screw yet it still happens why?
Old Feb 18, 2013 | 06:30 PM
NZXTInerTia's Avatar
You know you're new when you bump seven year old thread... Please refine your statement/question because I can't (someone tell me if I'm the only one) read why you're asking.
Old Feb 26, 2013 | 11:48 AM
well like it says in the post it cuts out and screechs and stuff so i was asking why it does that and if anyone can help me sorry im not a vetrin on how this message board works and what and how exactly im suppose to post stuff i just so happend to stumble uppon this site while reserching my problem and found it to be kinda usefull so i thought id ask on here but my post does ask if anyone knows why the im having the problem and if anyone could help thanks
Old Feb 26, 2013 | 10:08 PM
holmesnmanny's Avatar
Did you test whatever it was that you ran that ground to to see if it's a decent ground ? Run the ground wire straight to the negative terminal and see if that fixes it.
b16_swap
Mar 30, 2011 06:51 PM
Mishka24
Honda Fit
Jun 24, 2010 11:15 AM
95ACEX
Audio / Security / Video
Aug 8, 2006 07:34 PM
Eucalyptus lude
May 22, 2005 07:16 PM
shadowdawn
Aug 9, 2003 06:23 PM
