Help:Car running really rich
Old Aug 7, 2006 | 09:22 AM
kowekiller's Avatar
Default Help:Car running really rich
1994 civic ---So we did some testing this weekend and have found nothing to work.Here is a list of stuff we checked:
Changed map sensor
Changed ecu
Changed spark plugs
Set timing
Set idle
Pulled the injectors(no leakage)
Watched the injector spray pattern(looked normal)
Any other suggestions!There is a rich black smoke comming from the exhaust.We are stuck.What else could it be?
Old Aug 7, 2006 | 09:49 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Help:Car running really rich (kowekiller)
bad O2?
Whats the setup? All stock?
Old Aug 7, 2006 | 10:06 AM
kowekiller's Avatar
Default Re: Help:Car running really rich (SkoundrelUSA)
Cai
header /full exhaust
fpr set at 40psi
mild street port
not to much stuff to cause this.Did change the o2 sensor awhile back,but put on one from a 2000 civic and had to change the wires over for it to work right.Now that you mention it I will check that.Thanks
Bowl_of_Rice
Jun 17, 2011 09:23 PM
daje00
Dec 11, 2010 08:38 PM
Shonn
Oct 16, 2006 04:29 AM
s_vares
13
Jan 4, 2006 06:23 AM
AllMotorDA9
Oct 26, 2004 06:27 AM
