idle keeps dropping when i use electrical stuff
Old Aug 7, 2006 | 09:18 AM
Fat Chick Magnet's Avatar
Default idle keeps dropping when i use electrical stuff
fixed it!
Modified by dc2rtek at 10:23 AM 9/30/2006
Old Aug 7, 2006 | 09:28 AM
Lan's Avatar
Lan
Default Re: idle keeps dropping when i use electrical stuff (dc2rtek)
Loose alternator belt? Old or bad alternator?
Old Aug 7, 2006 | 09:43 AM
DC2 Mang's Avatar
Default Re: idle keeps dropping when i use electrical stuff (Lan)
does the car have trouble starting when it sits for a while?
and has your battery light ever come on?
Old Aug 7, 2006 | 10:14 AM
super jdm yo's Avatar
Default Re: idle keeps dropping when i use electrical stuff (DC2 Mang)
i have that same problem with my 90 gs. i got my alternator checked, and it was fine. i've been driving with it and nothing's gone wrong. i just don't like it.
Old Aug 7, 2006 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">does the car have trouble starting when it sits for a while?
and has your battery light ever come on?</TD></TR></TABLE>
takes close to 2 seconds for the car to start in the morning.
Old Aug 7, 2006 | 08:58 PM
Rhythmsnewsn's Avatar
yeah same here, anyone know whats going on?
Old Aug 7, 2006 | 09:16 PM
adip315's Avatar
Default Re: idle keeps dropping when i use electrical stuff (Rhythmsnewsn)
When the car is cold, you should turn on the accessories first for a couple of seconds and then crank the car over. This allows your fuel pump to prime.
Does your gauge cluster and other interior lights dim? If it does then it might be your alternator.
Old Aug 7, 2006 | 09:20 PM
Default Re: idle keeps dropping when i use electrical stuff (adip315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adip315 &raquo;</TD></TR><TR><TD CLASS="quote">When the car is cold, you should turn on the accessories first for a couple of seconds and then crank the car over. This allows your fuel pump to prime.
Does your gauge cluster and other interior lights dim? If it does then it might be your alternator.</TD></TR></TABLE>
my clock and radio light dim
Old Aug 7, 2006 | 11:02 PM
DC2 Mang's Avatar
check your alternator output with a digital multi-meter, it should be around 14 volts i believe
Old Aug 7, 2006 | 11:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">check your alternator output with a digital multi-meter, it should be around 14 volts i believe</TD></TR></TABLE>
eh how the hell do i do that?
Old Aug 7, 2006 | 11:52 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
First you are going to need a digtal voltage meter. Second you are going to ground the meter(black probe) to the battery and touch the (red probe) to the battery. Do it first with the car off to get a base reading. It should about 11.7-12.9 anything lower I would have the battery checked. Now start the car and let it come to idel. It should now read 14-14.6 volts. If its below 13.8 volts I would have the alt checked. Make sure all belts are good. And make sure all of your ground point on the chassie are good. Motor-tranny-battery have grounding straps.
Old Aug 8, 2006 | 06:57 AM
crx_88_si's Avatar
i would clean ou the IACV. The lower idle could reduce the output of the alt.
either that, or you need to bump up base idle using the screw.
blaze_125
28
Jun 27, 2007 08:52 AM
SupraRXZ
Mar 20, 2007 07:52 AM
nitrousrush
Nov 2, 2005 03:15 PM
daidilus
22
Dec 27, 2004 09:11 AM
crxtreme27
11
Aug 28, 2002 11:29 AM
