Suspension & Brakes Theory, alignment, spring rates....
ASR SI endlink adapter install. HELP
Old Aug 7, 2006 | 08:58 AM
SkankyEJ7's Avatar
Default ASR SI endlink adapter install. HELP
how do i get the old itr endlink bushings out of the swayba, to install the SI endlink adapters.
and if i switch to the function7 endlinks will these work with the billet adapters
Old Aug 7, 2006 | 01:59 PM
SkankyEJ7's Avatar
Default Re: ASR SI endlink adapter install. HELP (98ekhx)
please help
Old Aug 7, 2006 | 07:04 PM
chrisw85's Avatar
stick a screwdriver in there and take 'er out. it helps to slide the metal sleeve out first so you can flex the bushing more.
Old Aug 7, 2006 | 07:16 PM
SkankyEJ7's Avatar
Default Re: (chrisw85)
thats it, ok ill try it tomorrow
Old Aug 8, 2006 | 03:14 PM
SkankyEJ7's Avatar
Default Re: (98ekhx)
i got it out.
i just stuck a screw driveing in the and wiggled until the metal sleeve stuck out enough to get some pleirs on it and you can use your fingers on the rubber part
90reda
May 11, 2009 05:40 PM
shylo
Feb 9, 2006 08:55 AM
AK94GSR
Oct 14, 2005 11:50 PM
Willard
Nov 27, 2001 05:56 AM
