Have 96 Civic EX (EJ8) w/o Honda keyless remotes... do I need the OEM deck?
Old Aug 7, 2006 | 08:44 AM
Azxster's Avatar
Default Have 96 Civic EX (EJ8) w/o Honda keyless remotes... do I need the OEM deck?
I just acquired a 96 Civic EX, I currently do not have the Honda Keyless Remotes but I will be installing an aftermarket deck and an aftermarket alarm system. If I were to use my alarm remotes... will I still need the original deck (I am assuming not)?
I also have difficulties physically locking the driver's door from the inside... but if I were to use the key on the outside, it locks/unlocks fine. Will this affect my alarm keyless entry?
If I were to use the harness for 86+ Hondas and not the 96-98 non keylessone one... how do I rig it so I get the dome light feature to work?
Thanks!
Old Aug 7, 2006 | 10:08 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If I were to use my alarm remotes... will I still need the original deck (I am assuming not)?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> but if I were to use the key on the outside, it locks/unlocks fine. Will this affect my alarm keyless entry?
If I remember right, the keyless actuator works off the outside key lock rod... So no, it shouldn't affect operation with keyless... However, if you want to fix the problem, pull the door panel off, and then remove the vapor barrier. Follow the lock rod from the inside lock switch (not the electric switch but the plastic piece you use to lock/unlock)... Follow that rod over to a plastic oval shaped piece that connects to another rod. Use some wd40 or other cleaner/lubricating type oil and remove all of the grit/dirt that collects in there... My passenger side lock didn't work, and I did this and it works like new now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If I were to use the harness for 86+ Hondas and not the 96-98 non keylessone one... how do I rig it so I get the dome light feature to work?</TD></TR></TABLE>
There's 2 pins that need to be jumped, but I'll be damned if I can remember which ones... Maybe FCM remembers..
Old Aug 9, 2006 | 11:26 PM
MilanoCivic97's Avatar
Default Re: Have 96 Civic EX (EJ8) w/o Honda keyless remotes... do I need the OEM deck? (Azxster)
nah...but the dome light wont work.
Old Aug 10, 2006 | 05:02 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">nah...but the dome light wont work. </TD></TR></TABLE>
Thanks for posting a response to a question that was answered 3 days ago... Good job noob...
Old Aug 10, 2006 | 09:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote"> Maybe FCM remembers.. </TD></TR></TABLE> Nope, I just use a set of these... http://www.scosche.com/scosche...HAK3B or one of these... http://www.scosche.com/scosche...HA02B and one of these... http://www.scosche.com/scosche...HA04B
Neat and easy, no cut oem wires, I guess you could always get the jumper plug, see which wires it jumps then return it. 94
Old Aug 10, 2006 | 08:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for posting a response to a question that was answered 3 days ago... Good job noob... </TD></TR></TABLE>
thanks for being a jackass with your useless post
Old Aug 11, 2006 | 04:34 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">thanks for being a jackass with your useless post </TD></TR></TABLE>
My pleasure....
Old Aug 11, 2006 | 05:00 AM
Azxster's Avatar
How would I use the HA02B and the HA04B together?
I have the HA02B but am to cheap to buy the new harness.
Where would the HA04B plug into? That is the first I've seen.
Old Aug 11, 2006 | 05:11 AM
B18C_EJ8's Avatar
HA02B is the deck harness to add an aftermarket deck to the factory wiring... The other plugs into the green alarm plug...
Old Aug 13, 2006 | 07:05 PM
Azxster's Avatar
Do I need this kit?
http://www.audio-discounters.com/99-7891.html
I was told it wasn't necessary but the InstallDR said I should. It costed me $15 CDN but haven't got the chance to pick it up yet. I can pull out the factory deck without any tools (previous owner must have not mounted it), what can I do to prevent this?
Old Aug 13, 2006 | 07:19 PM
B18C_EJ8's Avatar
You don't need it, but it makes it look a lot nicer... If you look at your factory radio, it's not a perfect rectangle, it's got that weird angle on the left side... That kit fills that left hand gap, and cleans it up.
bassbaptism
Nov 9, 2014 05:53 PM
95EG2
May 28, 2010 06:26 PM
7808
Audio / Security / Video
Dec 22, 2005 03:36 PM
RadHaz75
Nov 24, 2004 10:11 AM
