ecu chipping for crome/uberdata or hondata
Old Aug 7, 2006 | 06:23 AM
HKSone's Avatar
Default ecu chipping for crome/uberdata or hondata
I just researched a little about chipping ecu, but i have questions; is the uberdata, crome just more simple ems because they dont have any other addition circuit boards or hardware inside? I believe the circuit board for hondata s100 is only for the nitrous option and the a/c cutout option? So basically am i just paying extra for those two options if i get the s100 or s200?
For examble if I use this kit from here: http://<a href="http://www.moates.ne...html</a><br />
Is this pretty much a universal kit, The only thing the makes the tunning different I guess would be which program is used to tune the car with, but if a chip was tune on a either crome, uberdate, hondata can be used on this universal kit? I would have that 4 pin header for datalogging that is require for using Hondata is that correct?
Will i be able to return back to stock map easily, for smog purpose? I've heard a switch can be installed? or can i take off the jumper?
And will my knock sensor function correctly still?
I'm running jdm itr pistons with gsr block and head so I might get detonation. I would get a p28 and get that chipped but, I still want to retain my knocksensor on my p72 because it gets really hot where i live in the summer its around 100+ degress so I can be safe side. Or will it even help at all? I've seen some tuners disable the ks, after ecu chipping but why?
thanks
Modified by HKSone at 2:14 AM 8/8/2006
Old Aug 8, 2006 | 04:20 AM
HKSone's Avatar
Default Re: ecu chipping for crome/uberdata or hondata (HKSone)
Old Aug 8, 2006 | 09:24 AM
Formula1's Avatar
Well, I can tell you after doing a good night's reasearch (5+ hours reading about crome and uberdata + previous knowledge of hondata and talking to friends who are tuners) that the closest thing to uberdata/crome from hondata is the s300 because you can tune it yourself. As far as I can tell, with hondata you're paying for the name and stability, not to say that crome or uberdata aren't stable, just saying that hondata guarantees it.
I can't say much about datalogging with hondata but I'd guess you'd go about it the same way with those 4 pins. And as for the knock sensor, I don't know on any of your questions but I've read the same thing about tuners disabling the knock sensor.
Old Aug 9, 2006 | 07:49 PM
mtber's Avatar
Default Re: ecu chipping for crome/uberdata or hondata (Formula1)
Read: http://phearable.net/tech/efibeginnerguide.html
http://pgmfi.org http://forum.pgmfi.org
http://www.tunewithcrome.com
http://www.hondata.com
Old Aug 14, 2006 | 12:52 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ecu chipping for crome/uberdata or hondata (mtber)
FYI, I'm pretty sure the factory knock sensor is useless over 4000 rpms. After that it can't tell the difference between engine noise and detonation.
Civic Hybrid
May 29, 2006 02:02 PM
nsxjr2
Jul 17, 2004 11:53 AM
JunIntegra
Apr 8, 2004 06:44 PM
98typer794
Apr 22, 2003 07:03 AM
ZColeon
Mar 8, 2002 01:09 PM
