96 spec R brake question?
Old Aug 7, 2006 | 06:14 AM
YTYPER's Avatar
Default 96 spec R brake question?
Just helping my friend to ask this question:
He change to 96specR 4x114.3 brake conversion on his EK 5 years ago, and now need to change brake rotors (front and rear). Anyone here can let us know what USDM Honda cars rotors may fit on the 96specR 4x114.3? The size of the disc is the same as normal Integra but the 4 holes and the center hub space make us confuse now, so hope there will be someone here can solve our question please! Thanks
Old Aug 7, 2006 | 06:51 AM
YumVTEC's Avatar
Default Re: 96 spec R brake question? (YTYPER)
you should have searched. this has been covered many times.
his only option unless he wants to upgrade front calipers and pads is to buy GSR rotors and have them re-drilled 4x114.3
Prelude VTEC rotors will bolt right up, but they are larger in diameter and i don't believe they will fit under the stock calipers, so he would need to get Prelude VTEC or ITR or Legend or NSX calipers + pads. and that is just for the front.
Old Aug 7, 2006 | 08:14 AM
BlueIntegraBoy's Avatar
Default Re: 96 spec R brake question? (YumVTEC)
He can use Prelude rotors with 98 spec or USDM ITR calipers. It all bolts up.
Old Aug 7, 2006 | 09:08 AM
YTYPER's Avatar
Default Re: 96 spec R brake question? (BlueIntegraBoy)
Thanks for helping!
But how about the rear? Thanks
Old Aug 7, 2006 | 10:46 PM
pArAdOxsqUArE's Avatar
i'd like to know also.. bump for someone who asked before i did
Old Aug 9, 2006 | 04:27 AM
YTYPER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">He can use Prelude rotors with 98 spec or USDM ITR calipers. It all bolts up.</TD></TR></TABLE>
Thanks for helping again, it really works perfect but do u know what can we get for the rear rotors please! Thanks!
Old Aug 9, 2006 | 08:10 AM
irishone's Avatar
what about 99 2.3 CL rotors. they're rotor over hub, and you can use them doing a roh conversion on 90-97 accords and teh stock calipers/brackets still work. I'm assuming these would be a direct replacement for the front.
DuongBros.
Suspension & Brakes
Oct 18, 2008 02:04 PM
DAchiko
Sep 11, 2007 08:06 PM
cloproductions
Dec 6, 2004 01:49 AM
zRd#1
Mar 27, 2004 08:24 PM
L8apex
Jul 23, 2003 10:26 AM
