car over heating!
Old Aug 7, 2006 | 02:52 AM
yz125rider21's Avatar
Default car over heating!
well my buddys car has been over heating lately and its full of water and I dont see the waterpump leaking one bit. Like we be driving down road turn heater full blast and dont even feal heat coming out of it. I was wondering if you all think its the thermostat??? I know the fans are coming on....need help asap
Old Aug 7, 2006 | 04:02 AM
Speed--Freak's Avatar
The thermostat is stuck shut.
Old Aug 7, 2006 | 07:48 AM
Duane_in_Japan's Avatar
Default Re: (Speed--Freak)
Start it up cold and monitor the two radiator hoses nearer to the radiator. One will heat up first then as the thermostat opens the other will heat up to almost an equal temp, the fan switch is near the thermostat screwed into the aluminum housing, it is getting hot even though the water may not be flowing so the fan will come on, do not turn on the AC, the thermostat may be ok but you have air in the system but I vote for a thermostat, I do more Honda stats than any other car.
Old Aug 7, 2006 | 08:23 AM
Loserkidwac's Avatar
Default Re: (Duane_in_Japan)
You can take the thermo out boil some water with a thermometer in it...put a stick/pencil/rod across the top of the pot and hang the thermostat from a string into the water, don't let it touch the sides because that may give you a falsh conclusion...now watch the thermo I believe it should open at about 190 degrees
Old Aug 7, 2006 | 08:48 AM
i slam guys's Avatar
WATER WETTER WORKS
Old Aug 7, 2006 | 08:55 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Start it up cold and monitor the two radiator hoses nearer to the radiator. One will heat up first then as the thermostat opens the other will heat up to almost an equal temp, the fan switch is near the thermostat screwed into the aluminum housing, it is getting hot even though the water may not be flowing so the fan will come on, do not turn on the AC, the thermostat may be ok but you have air in the system but I vote for a thermostat, I do more Honda stats than any other car.</TD></TR></TABLE>
agreed
Old Aug 7, 2006 | 11:27 AM
Default Re: (i slam guys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i slam guys &raquo;</TD></TR><TR><TD CLASS="quote">WATER WETTER WORKS</TD></TR></TABLE>ok smart one.....how about you reread it and see that it was full....cause while your trying to slam guys I am slamming cars...muahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Start it up cold and monitor the two radiator hoses nearer to the radiator. One will heat up first then as the thermostat opens the other will heat up to almost an equal temp, the fan switch is near the thermostat screwed into the aluminum housing, it is getting hot even though the water may not be flowing so the fan will come on, do not turn on the AC, the thermostat may be ok but you have air in the system but I vote for a thermostat, I do more Honda stats than any other car.</TD></TR></TABLE>thanks for the info mate I be going home to help him out tonight!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">You can take the thermo out boil some water with a thermometer in it...put a stick/pencil/rod across the top of the pot and hang the thermostat from a string into the water, don't let it touch the sides because that may give you a falsh conclusion...now watch the thermo I believe it should open at about 190 degrees </TD></TR></TABLE>thanks mate I knew about that before I wanted to start pulling anything off I wanted to double check
Old Aug 7, 2006 | 11:29 AM
Suck my DX's Avatar
Default Re: (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">ok smart one.....how about you reread it and see that it was full....cause while your trying to slam guys I am slamming cars...muahaha
ur so cool
Old Aug 7, 2006 | 01:13 PM
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
ur so cool</TD></TR></TABLE>
There goes teh ghey talk out your mouth again.....
Old Aug 7, 2006 | 09:18 PM
He was serious about the water wetter. It's an actual product that increases the cooling capacity by making better heat transfer.
FYI
Old Aug 8, 2006 | 12:21 AM
SiMateoAko's Avatar
make sure the radiator is bled properly. Even a little air in the system will make you overheat.
http://www.honda-search.com/se...iator
Old Aug 9, 2006 | 04:42 PM
Default Re: (SiMateoAko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiMateoAko &raquo;</TD></TR><TR><TD CLASS="quote">make sure the radiator is bled properly. Even a little air in the system will make you overheat.
http://www.honda-search.com/se...iator</TD></TR></TABLE>
thats what it was he didnt bother telling me he flush it all out but he said he did it a couple months ago....sure enough we open the bleeder screw and out came steam lol....solved the problem just like that....guess the air bubble finally got to where it needed to be haha
84dime
Sep 16, 2009 04:02 PM
Ransom
17
Aug 31, 2007 08:47 PM
twenty
Jul 21, 2005 08:36 AM
technine
22
May 9, 2005 12:47 PM
