Will JDM DB8 Type R window switches work in my 1997 DB7?
Old Aug 6, 2006 | 11:46 PM
no show no go's Avatar
Default Will JDM DB8 Type R window switches work in my 1997 DB7?
Just as the topic states. Sorry if I'm in the wrong forum. Just wanted to know b/c I have to pay for them tomorrow. And I"m paying $45 local pick up. Is that too much? Thanks in advanced for all the help.
Old Aug 6, 2006 | 11:53 PM
bg-33p's Avatar
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (no show no go)
If they're JDM wont they be on opposite sides? Since their cars are RHD and ours are LHD? I'm pretty sure they'll fit but you have to ask the passenger to control the side mirrors
Old Aug 6, 2006 | 11:56 PM
DBAl's Avatar
If it's just the switches then you can put them in the right doors so you don't have to worry about that.
Why are you buying new switches?
Old Aug 6, 2006 | 11:57 PM
Naruto's Avatar
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (teggysue)
They will fit. And if you do a search, I believe there was a write up on it not too long ago on someone fitting it into the LHD DB
Old Aug 7, 2006 | 12:11 AM
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (Naruto)
i searched. . . guess I didn't search hard enough. Thanks for the help.
Old Aug 7, 2006 | 02:00 AM
EnjoyTheRideDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">They will fit. And if you do a search, I believe there was a write up on it not too long ago on someone fitting it into the LHD DB </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no show no go &raquo;</TD></TR><TR><TD CLASS="quote">i searched. . . guess I didn't search hard enough. Thanks for the help. </TD></TR></TABLE>
Old Aug 7, 2006 | 02:20 AM
TURBODC4TEG's Avatar
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (EnjoyTheRideDC2)
all you go to do is put the jdm cover on usdm on controls.
Old Aug 7, 2006 | 06:00 AM
Duane_in_Japan's Avatar
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (TURBODC4TEG)
The face plates even look symmetrical in your photo, nice carbon fiber look.
They will not work on the passenger door since all the wireing is not there. In Japan, it is popular to get your old face plates dipped to look like carbon fiber or wood grain or many other styles.
I can see that the area around the window lock button is not symmetrical, sis you notice a difference with the shape of the section down inside the cutout, of course it still works just fine.
Old Aug 7, 2006 | 07:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG &raquo;</TD></TR><TR><TD CLASS="quote">all you go to do is put the jdm cover on usdm on controls. </TD></TR></TABLE>
Simply put, but not that simple buddy....
Try just unscrewing top plates and swapping them over.....you'll see...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">The face plates even look symmetrical in your photo, nice carbon fiber look.
I can see that the area around the window lock button is not symmetrical, sis you notice a difference with the shape of the section down inside the cutout, of course it still works just fine.</TD></TR></TABLE>
Good eye! There's hint #1...
Old Aug 7, 2006 | 11:03 AM
I think I suck at searching. I officially told the guy I didn't want to buy it anymore b/c I thought it would be too hard to install. Could someone enlighten me on the thread posted or how to actually do it? How much would you guys pay for it? Thanks,
-jordan
Old Aug 7, 2006 | 11:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Good eye! There's hint #1... </TD></TR></TABLE>
well i did it along time ago can't remember all the steps, isn't rocket science
Old Aug 7, 2006 | 03:48 PM
well i did it along time ago can't remember all the steps, isn't rocket science</TD></TR></TABLE>
Very true....not rocket science indeed. Just out of curiousity, was your install done on a dc chassis or a db chassis? Because the dc window switches are much easier to swap over. Not to mention, the jdm cover actually screws onto the usdm switch assembly. The db cover plate will not screw onto the usdm switch assembly.
Old Aug 7, 2006 | 05:25 PM
00IntegrAllmotoR's Avatar
HT Black OPs
The passenger one goes right on, the driver can be a PITA. If your using the usdm switches which is what i did, then you have to sand down the front R on the jdm window switch cover. If that makes sense. After that you have to do some cutting of the bottom clips of the jdm cover. Kinda a trail and error thing.
Old Aug 7, 2006 | 06:53 PM
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">The passenger one goes right on, the driver can be a PITA. If your using the usdm switches which is what i did, then you have to sand down the front R on the jdm window switch cover. If that makes sense. After that you have to do some cutting of the bottom clips of the jdm cover. Kinda a trail and error thing.</TD></TR></TABLE>
I had to rig my own way of mounting the whole switch assembly to the door panel itself. I used zip ties and its help up great for almost 2 years now!
Old Aug 21, 2006 | 11:53 PM
Naruto's Avatar
Hell, when I did it to my 2 door I used the actual jdm switch. Only thing is, I no longer have the automatic window roll down feature and if I push that on off switch, I lose the function to the driver's side window...not the passenger side Though someone stated that won't work the same with the 4 doors......
Old Aug 22, 2006 | 10:58 AM
Hell, when I did it to my 2 door I used the actual jdm switch. Only thing is, I no longer have the automatic window roll down feature and if I push that on off switch, I lose the function to the driver's side window...not the passenger side Though someone stated that won't work the same with the 4 doors......</TD></TR></TABLE>
I have my automatic window roll down feature still....on the driver's side just like its supposed to be...
Old Aug 22, 2006 | 11:32 AM
QuAcK5dC2's Avatar
yeah they work but the automatic roll down ft works for the passenger side on the switch, but other than that,DO IT
Old Aug 22, 2006 | 01:32 PM
Default Re: (QuAcK5dC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuAcK5dC2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah they work but the automatic roll down ft works for the passenger side on the switch, but other than that,DO IT </TD></TR></TABLE>
Dont know if you're directing that comment towards me, but my Drivers Side window can roll down Automatically as if nothing we're changed. My passenger side window will not automatically roll down. And yes, I am using the JDM Integra DB8 R Window Switches/ CF panel
Old Aug 22, 2006 | 03:48 PM
Default Re: (EnjoyTheRideDC2)
I do not remember any cars with passenger side auto windows, at least none that I have seen yet.
Old Aug 22, 2006 | 04:40 PM
bg-33p's Avatar
Default Re: (Duane_in_Japan)
lol the on/off thing looks funky.
Old Aug 22, 2006 | 11:24 PM
Naruto's Avatar
I have my automatic window roll down feature still....on the driver's side just like its supposed to be... </TD></TR></TABLE>
yeah yeah yeah so I took the easy route and didn't want to modify the jdm cf plate Its alright though....I don't mind it at all and I've never had a problem with the car so its alllll good
Old Aug 23, 2006 | 01:04 AM
yeah yeah yeah so I took the easy route and didn't want to modify the jdm cf plate Its alright though....I don't mind it at all and I've never had a problem with the car so its alllll good </TD></TR></TABLE>
But the mod isn't too tough and in the event that you were to make a mistake, it wont be extremely noticeable. But, all that matters is that you're cool with it and you got your CF window panel!
Old Aug 23, 2006 | 01:13 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
hum, i don't know about their fitment, BUT, I KNOW MY USDM carbon fiber ITR parts for sale will fit!!!!!!!!!!!!!!
Old Aug 23, 2006 | 01:23 AM
Default Re: Will JDM DB8 Type R window switches work in my 1997 DB7? (It's BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">hum, i don't know about their fitment, BUT, I KNOW MY USDM carbon fiber ITR parts for sale will fit!!!!!!!!!!!!!!</TD></TR></TABLE>
Who's fitment of what?
Old Aug 23, 2006 | 12:31 PM
Tight Fit's Avatar
not to thread jack or anything but does anyone know anyone selling these window switches for a DC they are the only carbon pieces missing from my interior.....
doublethink
Mar 4, 2012 09:14 PM
02blackcivic
Sep 23, 2009 03:32 PM
Hatchdude
Dec 26, 2004 02:52 PM
rhdef8
41
Nov 28, 2004 02:33 PM
spencedogg
25
Jan 23, 2004 08:17 AM
