Dyno'd result of ITR1244 ( CTR pistons, M22xx........) :|
Click here to watch "itr-dyno-pull"
Mod list
2001 B18C5
CTR pistons (12.5 ish CR)
RM M22XX
GE camgears (0,0)
RM Ti retainers, dual valve springs.
AEBS IM + IM heatshield gasket
Prototype V'stack with K&N filter.
An-R Standard header with merge collector
Mugen TL. 2.5" all the way
RC 310cc
4.9 FD
excedy organic racing clutch
Fidanaza 7 lbs flywheel
socketed P28 ECU tuned with Crome pro
Vtec X over @ 6100 , Redline 9125
base run.
Final run
Here's the video.
http://media.putfile.com/itr-dyno-pull
link doesnt work?
they let the throttle off at 8000 rpm and just broke my goal which was 200 whp . by .8 whp LOL
what do you guy think about the smoke from my exh? is this bad ?
any comments welcome
Modified by itr1244 at 2:03 AM 8/7/2006
Modified by itr1244 at 2:05 AM 8/7/2006
Modified by itr1244 at 2:46 AM 8/7/2006
Modified by itr1244 at 2:47 AM 8/9/2006
Mod list
2001 B18C5
RM M22XX
GE camgears (0,0)
RC 310cc
4.9 FD
base run.
Final run
Here's the video.
link doesnt work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">Coolio
. I just hit the rollers last Thursday for my final tune as well.</TD></TR></TABLE>
what was your set up and what #'s did u get?
. I just hit the rollers last Thursday for my final tune as well.</TD></TR></TABLE>what was your set up and what #'s did u get?
Yeah your hp and torque curves look a little off-beat. Should be more linear. Not unless I am seeing things, but does your final run show that you're hitting above 190whp at 3k rpm? Must be my vision...
Honestly, I would have expected more.
Have you done a compression test on the motor yet? Id like to know what those numbers are.
I cant watch the video here at work, what color is the smoke and how bad is it? Only at WOT?
who tuned this thing??? why did he compress the air-fuel graph so it looks flatter?? thats an old trick of a crappeh tuneR. what kind of timing are you running? good power, but i'd expect a little more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">what was your set up and what #'s did u get?</TD></TR></TABLE>
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
T1R testpipe and catback
UR pulleys
plus some other stuff
internals are 100% STOCK and redline is stock. vtec x-over at 5200rpm
195.5whp and 138ft/tq
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
UR pulleys
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
UR pulleys
195.5whp and 138ft/tq</TD></TR></TABLE>
that is really good. On a dynojet? do you have the dyno sheets you could pm me?
I didn't know stock cams could break the 190 whp.
Modified by realis9 at 1:15 PM 8/7/2006
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
UR pulleys
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
UR pulleys
that's pretty damn crazy man. makes me think i just burned the cash for no reason.
Comptech Icebox
Spoon spec TB
IB P'n'P IM
Outlaw gasket kit
AEM cam gears
Toda header
UR pulleys
Nice freak motor you have there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket »</TD></TR><TR><TD CLASS="quote">Oh yeah, I forgot about the Hondata s200 and it was on a dyno dynamics dyno.
Voi la!
We some reasoning behind those numbers.
Voi la!
