front windshield wipers. too long? why they hit ??
just installed some windshield wiper and arms for my 95 RS. it didnt come with a passenger side one so i installed and replaced my driver side one too b/c it was old. thing is these 2 windshield wipers are longer then my old one, ( they came from a friends crashed dc2 ) wondering if i installed them wrong? i put the longer one for driver side and shorter one for passenger, but thing is when its at rest, not moving, it seems as the driver one is so big its touching the passenger one. did i install them correctly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">Sounds like you need to rotate it on axis slightly.</TD></TR></TABLE>
what does that mean.. and how would i do that..??
means your wiper linkage isnt sitting on correctly or its loose. its a 10mm bolt loosen it, align the wiper linkage, then tightly close the bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrada9 »</TD></TR><TR><TD CLASS="quote">means your wiper linkage isnt sitting on correctly or its loose. its a 10mm bolt loosen it, align the wiper linkage, then tightly close the bolt.</TD></TR></TABLE>
the black bolt correct.. its tight, but ill try to loosen it and move the wipers up a bit see if that helps..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangebarius »</TD></TR><TR><TD CLASS="quote">im pretty sure the longer one goes on the passenger side.</TD></TR></TABLE>
i doubt it b/c i tried that and it was longer then the window.. i searched on HT and it said longer one for driver side.
My 98 had the same problem... I had to take the 14 mm nut (12 or 14... I don't rightly remember) off where the wiper arm meets the linkage and remount the arm positioned counter clockwise about an 1/8 of a turn. It was all good after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex voto »</TD></TR><TR><TD CLASS="quote">My 98 had the same problem... I had to take the 14 mm nut (12 or 14... I don't rightly remember) off where the wiper arm meets the linkage and remount the arm positioned counter clockwise about an 1/8 of a turn. It was all good after that. </TD></TR></TABLE>
ic.. thanks for the info. prolly gonna do that.
FuNkDrSpOt
Feb 12, 2007 08:28 PM
WhiteOnRice
Dec 15, 2006 09:17 AM
