ls vtec... couple questions
Old Aug 6, 2006 | 06:23 PM
wht92teg's Avatar
Default ls vtec... couple questions
ok so i have a couple question for everyone out there... i am building an ls/vtec and have come across a situation...
i bought a b18a1 block for 150 bucks, ripped it all apart and found that the #1 cylinder was froze, and by froze i mean needed a BFH to get it to even budge.
So my question is since i need to get it bored should i go all out? say 84-84.5mm? and then get a block gaurd or should i get a set of darton sleeves?
Old Aug 6, 2006 | 07:04 PM
95 integra's Avatar
Default Re: ls vtec... couple questions (wht92teg)
all out = cracked sleeve. If you want to go 84mm+ then you really need to get sleeves. Thats assuming you're going ls/vtec, have "performance" goals at hand and plan on revving past 6800 or so.
Old Aug 6, 2006 | 07:48 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht92teg &raquo;</TD></TR><TR><TD CLASS="quote">ok so i have a couple question for everyone out there... i am building an ls/vtec and have come across a situation...
So my question is since i need to get it bored should i go all out? say 84-84.5mm? and then get a block gaurd or should i get a set of darton sleeves?</TD></TR></TABLE>
i wouldn't bore that much on stock sleeves, I definately recommend new sleeves
Han Solo
Feb 4, 2006 07:33 AM
lube
May 12, 2002 07:35 PM
