b18 Head, D16z6 block, cable tranny?
Old Aug 6, 2006 | 03:52 PM
AutoGodz's Avatar
Default b18 Head, D16z6 block, cable tranny?
Has anyone ever seen this setup? I cae across a car for sale, its a 88-91 crx, the cars basically a shell with nothing but a drivers seat, steering wheel and the motor. the doors welded shut so im assuming they were using the car for some kind of autocross. what im wondering is what kind of power they could get out of this setup and also just wondering why they did this.
its a b18 ls head with a d16z6 block, not sure exactly what tranny it is but its a cable tranny. looks all tock from the outside but who knows whats going on with the internals. anyone ever seen this or know what kind of power it can produce?
Old Aug 6, 2006 | 04:33 PM
vg7z's Avatar
u cant put an LS head on a d16z6 block dumbass. You can tell if its cable or hydraulic if theres a sl;ave cylinder. whoevers sellin u this car is a moron, and so are you. get a real mechanic to look at it
Old Aug 6, 2006 | 04:38 PM
polymath's Avatar
Default Re: (vg7z)
What you saw was probably a dohc ZC. At a glance it could be confused with an LS valvecover, and it could have a d16 block bolted to it. Its basically a dohc d-series. And if its a 88-91, then it should be a cable-actuated clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">u cant put an LS head on a d16z6 block dumbass. You can tell if its cable or hydraulic if theres a sl;ave cylinder. whoevers sellin u this car is a moron, and so are you. get a real mechanic to look at it</TD></TR></TABLE>
great attitude.
Old Aug 6, 2006 | 04:57 PM
AutoGodz's Avatar
Yea i just thought it was an LS because of the valve cover. How much power do you think there getting out of this?
brandIZZLE!'s Avatar
R.I.P Little Brandon
Default Re: (Coyote1800cc)
Good call Coyote, some people need to lighten up around here, damn
Old Aug 6, 2006 | 10:28 PM
polymath's Avatar
Default Re: (AutoGodz)
I think they were rated 130 bhp at the flywheel...my wild guess would be maybe 100whp? If its really a D16z bottom end, then putting a ZC head on it would lower the compression, I believe. But who knows...if its some sort of a dedicated track car then its probably been rebuilt with some aim at making it faster. There's a mulititude of OEM pistons you can use when building d-series to give you a wide range of compression. Stock, they feel decently peppy in that chassis.
Old Aug 7, 2006 | 02:27 AM
91SiZ6's Avatar
Can't put a DOHC head on a SOHC block. And the pistons you use to raise compression in D blocks come from this motor, generally anyway.
Old Aug 8, 2006 | 09:27 AM
polymath's Avatar
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">...the pistons you use to raise compression in D blocks come from this motor, generally anyway.</TD></TR></TABLE>
...which is behind my reasoning for thinking that the compression would lower if you placed a ZC head on a d16z6 block - and the chambers are smaller on z6 head. But it doesn't really matter if, as you pointed out, you can't bolt a dohc ZC head onto a sohc block.
Perhaps the CRX had a dohc d16a1 underhood?
Old Aug 8, 2006 | 09:43 AM
NathanMorris's Avatar
pictures.
def. not a b18 head on a D block, possibly as someone said a ZC head, but I don't know how they could have gotten the ZC head on anything other than a ZC block.
Nathan
Old Aug 8, 2006 | 01:36 PM
polymath's Avatar
Default Re: (92Lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Lx &raquo;</TD></TR><TR><TD CLASS="quote">pictures.
Nathan</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coyote1800cc &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps the CRX had a dohc d16a1(1st gen Integra dohc engine) underhood?</TD></TR></TABLE>
CivicEF90
May 18, 2015 05:58 PM
TravisCadello
Mar 29, 2009 07:05 PM
tambara
Jan 5, 2007 10:57 PM
hondaguyexsi
Dec 13, 2005 04:01 PM
