Installed shifter bushings now problem.....
Old Aug 6, 2006 | 03:05 PM
vwtohonda's Avatar
Default Installed shifter bushings now problem.....
I just installed prothane shifter bushings into my car, and it feels as if the shifter doesn't want to move to much. I know it's suppost to be tighter, but i know it's not suppost to be this tight. I think i tightened the actual shifter it self down to tight. is that possible?? the bolt that holds teh shifter being to tight and hard to shift??
Old Aug 6, 2006 | 05:17 PM
vwtohonda's Avatar
Default Re: Installed shifter bushings now problem..... (vwtohonda)
bump
Old Aug 7, 2006 | 07:03 AM
vwtohonda's Avatar
ne1?
Old Aug 7, 2006 | 07:32 AM
non-VTEC's Avatar
you tightened the nut/bolt on the shifter to tight.
get under the car and loosen it a little until the shifter moves freely...
Old Aug 7, 2006 | 08:55 AM
slambedcivic's Avatar
Default Re: Installed shifter bushings now problem..... (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">you tightened the nut/bolt on the shifter to tight.
get under the car and loosen it a little until the shifter moves freely...</TD></TR></TABLE>
^ for a stock shifter. however most aftermarket ones come with bearings in the lower parts and also include spacers/washers. make sure you use those if you have an aftermarket shifter.
MiamiEgGSr
Nov 4, 2007 04:37 PM
CTR-GSR
Feb 24, 2006 09:47 PM
BSERIEuS
Aug 25, 2005 09:07 AM
slash00R
Nov 1, 2004 07:23 PM
