Where do the ring gaps go on Wiseco pistons?
Old Aug 6, 2006 | 01:02 PM
PhatBoy5015's Avatar
Default Where do the ring gaps go on Wiseco pistons?
I know where the ring gaps for the expansion ring gaps go. But where do the top two rings go? I know where they go on OEM Honda pistons, but I also know that Wiseco pistons have different gap placements.
Please reply quick.
Old Aug 6, 2006 | 02:45 PM
Default Re: Where do the ring gaps go on Wiseco pistons? (PhatBoy5015)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">I know where the ring gaps for the expansion ring gaps go. But where do the top two rings go? I know where they go on OEM Honda pistons, but I also know that Wiseco pistons have different gap placements.
Please reply quick.</TD></TR></TABLE>
Bump, anyone know?
Old Aug 6, 2006 | 03:51 PM
non-VTEC's Avatar
the ring gap positions from the OEM pistons are perfectly fine with aftermarket pistons.
Old Aug 6, 2006 | 05:26 PM
Default Re: Where do the ring gaps go on Wiseco pistons? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the ring gap positions from the OEM pistons are perfectly fine with aftermarket pistons.</TD></TR></TABLE>
Ok, so can someone tell me exactly where each ring goes, because I keep getting conflicting answers.
Old Aug 6, 2006 | 06:06 PM
NJIN BUILDR's Avatar
The reality is it really doesn't matter.I stagger them when I assemble them but the rings rotate in the grooves and don't stay where you put them for very long.Pressure does not care to much about line of site so you could line them all up and the engine would run just fine.
Old Aug 6, 2006 | 06:34 PM
non-VTEC's Avatar
Ok, so can someone tell me exactly where each ring goes, because I keep getting conflicting answers.</TD></TR></TABLE>
check your helms manual.....it's in there.
p.s. the rings will move around anyway.....as long as they are not in the major and minor thrust sides and not lined up with the piston pin's you are good to go.
Old Aug 7, 2006 | 08:52 AM
Nors's Avatar
89hybrid
Nov 18, 2014 03:02 PM
92integraVTECgsr
26
Feb 15, 2007 03:06 PM
rusted_eyes
17
Jul 13, 2004 05:28 PM
Hoosier Daddy
Nov 7, 2003 12:53 PM
