gapping spark plugs
Old Aug 6, 2006 | 12:02 PM
jikespingleton's Avatar
Default gapping spark plugs
first off, what spark plugs would u guys recommend for a 94 gsr. i was thinkin denso iridiums cuz i can get them for free. second, what spec do i need to gap em too?
Old Aug 6, 2006 | 12:35 PM
Brick Top's Avatar
NGK are oem spec recommended. i gap mine at .040.
Old Aug 6, 2006 | 06:11 PM
DJslepton's Avatar
Default Re: (brick top)
i believe its .052
Old Aug 6, 2006 | 06:49 PM
Brick Top's Avatar
ngk comes pre gapped at .044
Old Aug 8, 2006 | 06:38 PM
wats oem spec for an 88 crx?
Old Aug 8, 2006 | 08:03 PM
B20C5 Turbo's Avatar
New User
Default Re: gapping spark plugs (jikespingleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton &raquo;</TD></TR><TR><TD CLASS="quote">what spark plugs would u guys recommend for a 94 gsr?</TD></TR></TABLE>
NGK. If you want to use Iridium [I like them], use NGK IFR6E11 or BKR6EIX-11. They are pre-gapped at the factory recommended 1.1mm. DO NOT attempt to re-gap Iridium plugs. The center electrode is usually very thin and the Iridium coating on the tip can be easily damaged or completely knocked off. If you have a *really* good reason to adjust the gap, refer to this link:http://densoiridium.com/installationguide.php. Good luck!
mickey513
Jun 19, 2014 08:38 PM
dman81
Feb 2, 2014 11:10 AM
somejaykid
Jan 5, 2012 04:47 AM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
