eg shell,turbo kit, head, block, lots more....
1993 Honda Civic DX EG Hatchback Shell:
16x,xxx on chasis
Tockico Shocks
Tenzo R lowering Springs
CF OEM Style Hood
JDM Amber corner lights
Red/Clear Tail Lights
3pc Midwing
Full Interior
Apexi Exhaust
2.5" exhaust piping
Over all car is pretty clean........... 1700
Will NOT part out the shell. so please don't ask if i will sell the hood seperate, or the dash, doors, windows, etc.... I WON'T
JDM B18C3 (GSR) Head:
Not sure on the miles cause its a JDM Head
Head has been Port N Polished
Has a 3 angle valve job
550.00
****Will NOT include cams,dizzy,IM
JDM B18C3 ShortBlock:
Has almost 5K miles since rebuild
new oil pump
arp rod bolts
bored .20 over
new pistons
new piston rings
THE BAD: has a slight knock at about 2500 rpms. it needs new bearings.... Make offer for Shortblock
Drag Gen III B series Turbo Kit:
turbo manifold
t3/t4 turbo ...... 57 trim .60 a/r
JRC big FMIC
Stan's oil feed and return line
all chrome piping
HKS BOV
Tial 38mm WG with 7psi spring
WG dumptube
all couplings and clamps
2.5" downpipe
Its a complete turbo kit with about 4k miles on it or less. no shaft play on the turbo. perfect condition and will come with everything needed. I will NOT part out the turbo kit either, so please don't ask.
1750.00
if you have a GSR oil pan, i'll trade you my tapped oil pan .
Aebs GSR Intake Manifold.............. 175.00
CTR cams....................200.00
AEM adj. FPR..............80.00
DSM 450cc injectors with resistor box................80.00
GSR Motor Mounts..................125.00
B16 Tranny, no grinds, perfect condition.............. 500.00
12lb lighten flywheel....................100.00
GSR Shift Linkage......................125.00
GSR distributor.......................125.00
GSR OBD1 Wiring Harness, uncut.........175.00
chipped P28 ecu.........................175.00
Triple Guage Pod with guages
boost guage, a/f guage, oil pressure guage............150.00
5" tach with shift light (autogage).............85.00
got an obd0 LS distributor..............50.00
passenger side 92-95 civic headlight........30.00
oil pressure sensor........ 25.00
b&m fuel pressure guage....20.00
stock honda fpr......20.00
gsr starter.............80.00
gsr alt...obd1 ..........80.00
Thats about all i can think of. Let me know if anybody is interested in buying anything. all prices are pretty firm. not looking for any trades or anything
16x,xxx on chasis
Tockico Shocks
CF OEM Style Hood
3pc Midwing
Full Interior
Apexi Exhaust
2.5" exhaust piping
550.00
new oil pump
arp rod bolts
bored .20 over
new pistons
new piston rings
turbo manifold
JRC big FMIC
all chrome piping
HKS BOV
WG dumptube
2.5" downpipe
1750.00
yes i do.
the motor is still in the car. still starts up and everything.
there is just a slight knock at about 2500 rpms.
if you want the longblock, pm and let me know .maybe we can work something out.
Good Deal for the Shell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch »</TD></TR><TR><TD CLASS="quote">only pic i have righg now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch »</TD></TR><TR><TD CLASS="quote">1993 Honda Civic Dx Hatchback
16x,xxx on chasis
white ext.
blue int.
Exterior:
3 pc midwing
jdm amber corners
oem style CF hood
m3 style mirrors
red/clear tail lights
suspension:
15" konig wheels (black with chrome lip)
falken azeni tires up front
tokico shocks all the way around
tenzo r lowering springs
Motor:
JDM GSR B18c3 motor (been bored .20 over)
motor has 4,500 miles on it since rebuild
motor has:
micropolished and balanced crank
new pistons (stock gsr pistons)
new rings
arp rod bolts
new acl rod and main bearings
new oil pump
new water pump
new timing belt
Port N polished head
3 angle valve job
CTR cams
AEBS intake manifold
fuel pressure guage
aem adj fpr
B16 tranny
12lb flywheel
exedy clutch
chipped p28 ecu
powder coated valve cover
Drag Gen 3 Turbo kit (installed 2 weeks ago)
drag manifold
t3/t4 turbo
tial 38mm WG with 7psi spring
JRC fmic
chrome piping
hks bov
stan's oil lines
custom 2.5" dp
2.5" exhaust piping
apexi muffler
8mm spark plug wires
walbro 255lph fuel pump
Interior:
all stock interior (dark blue color)
5" tach with shiftlight
tripe guage pod with a/f guage, boost/vac guage/oil pressure guage
CF guage cluster overlay
Not sure on price yet. if your interested, pm me some offers and maybe we can work something out. trades: not sure on that either, but may consider, just let me know what you have in mind. </TD></TR></TABLE>
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch »</TD></TR><TR><TD CLASS="quote">1993 Honda Civic Dx Hatchback
16x,xxx on chasis
white ext.
blue int.
Exterior:
3 pc midwing
jdm amber corners
oem style CF hood
m3 style mirrors
suspension:
Motor:
motor has:
new rings
arp rod bolts
new oil pump
new water pump
new timing belt
3 angle valve job
CTR cams
fuel pressure guage
aem adj fpr
B16 tranny
12lb flywheel
exedy clutch
chipped p28 ecu
drag manifold
t3/t4 turbo
JRC fmic
chrome piping
hks bov
stan's oil lines
custom 2.5" dp
2.5" exhaust piping
apexi muffler
Interior:
julioboostamante
Appearance Build Threads
Jul 18, 2008 09:08 PM
boostedeghatch
Aug 4, 2006 06:23 PM
