my 404s are in, but...
mods:
crower 404s
crower valve springs and titanium retainers set
full-race camgears
b&m fuel pressure regulator with gauge
6 puck clutch rated at 400lbs of torque
cold air intake
a big header, I dunno what brand but its pretty big
I just put the cams in, the camgears are set at cero for now, and I actually have the stock FRP for now, and the cars starts but I have to step on the gas to start it and also I have to keep my foot on the gas to keep the car on, and I'm gonna try to turn up the idle to 1200-1500 but I also wanna know of any other ideas on how resolve this and if you guys know of any good reputable NYC, long island tuners,
crower 404s
full-race camgears
cold air intake
I reinstall my LS head with same setup as your and I can't idle my car so I look at my timing and it was off a teeth so I redo my timing belt and now it idle like my stock cams. My idle stay on 900 rpm
I got: crower 404s cams
crower dual valve spring with ti retainers
all on stock LS head and block
NO TUNING on stock LS ecu
bump! if i mixed up the plugs from the tps and map sensor since they both have the same plugs, would that cause my car to misfire and sputter
I never timed it after the head was put back in the car, I had set cylinders 1 and 4 at TDC and the stock camgears facing up b4 i took the head out, and evrythig went back into the car the exact way, how will I be able to check if the camgears skipped a tooth on the timing belt, and also how can i tell if the valves are bent
leak down test for bent valves. and for the timing, a good old fashioned timing light. they are very simple to use and will save you alot of heartache.
