ecu's
ok i got a b18a motor with 10.5:1 compression ratio. ive done some research and i need engine management, but i cant find anything for the pr4 (obd 0) ecu that i am using. my question is can i go obd 1 on the b18a motor? if so what ecu would work with my motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crampinyourstyle »</TD></TR><TR><TD CLASS="quote">ok i got a b18a motor with 10.5:1 compression ratio. ive done some research and i need engine management, but i cant find anything for the pr4 (obd 0) ecu that i am using. my question is can i go obd 1 on the b18a motor? if so what ecu would work with my motor?</TD></TR></TABLE>
There are programs that can be chipped for the OBD0 PR4 ecu. There are several people on this site who can help you out. If you are set on going to OBD1, you will need among other things, OBD1 injectors, an OBD1 ecu (PR4 or P74), and a wiring conversion harness.
