Good Tire combo....
Old Aug 5, 2006 | 07:28 PM
jdm_sir2's Avatar
Default Good Tire combo....
Well since my Konig's have been trashed by the accident i'm going to be rolling on some Black Del Sol VTEC wheels which are 14x5.5.....I'm not a big fan of skinny tires so since these tires are on there last leg I wanted to know if it's fine for me to run a 195/60/14 tire with a wheel spacer to widen the track to improve handling...the current tire size on the rims are 185/65/14 and well in my opinion they feel like the tire since there's not much of a contact patch that is has a bit of an oversteer effect....it's not much a difference in number but when you think about it with suspension and tire combos the slightest change makes a big difference....
Old Aug 5, 2006 | 07:37 PM
Slopoke's Avatar
Default Re: Good Tire combo.... (jdm_sir2)
Yes it will be fine.
I've run 205's on a 5.5 wide wheel with no problems.
Old Aug 5, 2006 | 07:49 PM
jdm_sir2's Avatar
Default Re: Good Tire combo.... (Slopoke)
So is there still a difference in handling?
Old Aug 5, 2006 | 08:51 PM
Slopoke's Avatar
of course.
wider = better.
Old Aug 5, 2006 | 09:12 PM
jdm_sir2's Avatar
Thats what i was thinking I just wanted to make sure that it was possible to run that tire set up the Del Sol VTEC rim not the fat fives but the skinny fives....
I saw somewhere that the most you can try to run on a 5.5 is a 215....so i'll so what tires around and make a good desicion...thats man i hope some more people can help out....
kriscabrera
Jan 25, 2012 06:01 PM
racerx510
Jun 5, 2011 05:48 AM
brandobot89
Oct 15, 2008 04:26 AM
erikiksaz1
Sep 2, 2006 01:52 PM
dclub01
May 24, 2003 07:45 PM
