LSVTEC question.
I have this so far...
fully machined block, .20 over.
stock ls crank (micropolished, the works)
jdm sir2 head (mild port/polish, 3 angle valve job, basic recondition job)
eagle h beam rods
SRP 11.5-1 forged pistons
ACL bearings
golden eagle girdle, gsr windage tray, pickup, and oil pan
golden eagle ls/vtec kit
type R oil pump
GSR water pump
GSR timing belt
skunk 2 pro series intake manifold
im sure im leaving something out...
anyways, my main concern is, what kind of fuel am i going to need to keep this thing on the road? chipped p28 and a fuel pressure regulator gonna cover it, or should i invest in megasquirt or something like that? Also, whats everyone's opinion on a chipped p28 w/no knock sensor. Am i in danger here? Please help, i've put a lot of time/money into this setup and i really need a cheap reliable solution to my tuning issue. Even if it's just enough to safely drive. Thanks.
eagle h beam rods
ACL bearings
type R oil pump
GSR water pump
GSR timing belt
http://www.pgmfi.org
You can have someone tune your setup using Crome/Hondata/Neptune (Crome being the cheapest) using the chipped P28 ECU. Any of these are far superior to Megasquirt, which I would never run on an engine I had more than $100 invested in.
Search for a tuner in your area, and consult them as to what is the best route. You may need to upgrade your injectors depending on how much power you want to make.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94lsvtec »</TD></TR><TR><TD CLASS="quote">That was very helpful and has helped me decide on what to do. I had no idea making my own chips would be so easy. Thanks man.</TD></TR></TABLE>
No problem, however for what you have invested in your engine and the experience with tuning that you have, you might want to consider contacting a tuner with a dyno close to you. There is a list of tuners stickied at the top of the Forced Induction forum. Here is the link: https://honda-tech.com/zerothread?id=1347699
If not get a wideband and stay safe/conservative with the timing until you can get the car on a dyno to tune it.
K20crx
May 29, 2004 03:12 PM
