fuse keeps on blowing
Old Aug 5, 2006 | 02:29 PM
TheTealHatch's Avatar
Default fuse keeps on blowing
my fuse for my instrument keeps on blowing everytime i put on a new one and everytime i turn the headlights on. i dont know whats wrong. you guys have any ideas what could be the problem? i try to check wires and everything but i still cant figure out the problem. any idea?
Old Aug 5, 2006 | 02:31 PM
philosofy1's Avatar
Default Re: fuse keeps on blowing (ackavong)
you have a short. there is a wire grounding out causing your fuses to blow every time. grab a voltage meter and get to the trouble shooting.
Old Aug 5, 2006 | 02:33 PM
sheBangZ's Avatar
what was the last thing you did with the car? lok there. i had the same problem and thot about it and the last thing i did was change out the cd player. sure enough i forgot one wire and thats why ifuses were popping.
Old Aug 5, 2006 | 04:09 PM
Default Re: fuse keeps on blowing (sheBangZ)
i had my alarm fixed and i saw that they changed the place where the grounded the wire.. could that be the problem?? cause i took out my deck and chekd if any wires were loose or untapped and other wires so maybe the grounding from the alarm?
Old Aug 7, 2006 | 12:11 PM
sheBangZ's Avatar
yup, the last thing yu did to your car is almost always the culprit.
Old Aug 7, 2006 | 12:35 PM
92redhatch's Avatar
a wire is definately grounding out. You definately have a short. I had the same problem last week. Dont get to frustrated because finding the wire is going to take a while. Good Luck!
Old Aug 8, 2006 | 12:25 AM
Default Re: (92redhatch)
yeah it was i went thru all my wires and i still couldnt find it and then finally i did it over again and again and it was solved
mxracer420
Jan 6, 2012 02:50 PM
boostedb18kid
Jan 18, 2008 08:29 AM
slammedef06
Audio / Security / Video
Dec 19, 2005 07:40 AM
Crasian
10
Jun 9, 2005 09:06 AM
tgctruly
Nov 8, 2004 12:12 PM
