proper way to use GM sycomesh
Old Aug 5, 2006 | 11:31 AM
BLUE EH3's Avatar
Help we my pennies
Default proper way to use GM sycomesh
I plan to change my oil and change my tranny fuild next week. How often should you change ur tranny fuild? How many quarts goes in ur B tranny?
BTW-Password JDM magnetic drain plugs for oil and tranny
Old Aug 5, 2006 | 12:13 PM
b16ej1lsd's Avatar
30k, 2.3qts.
Old Aug 6, 2006 | 09:25 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: proper way to use GM sycomesh (BLUE EH3)
any one else?
Old Aug 6, 2006 | 09:26 AM
Bense's Avatar
if you see high rpms more, change more frequently.
Old Aug 6, 2006 | 09:30 AM
chrisw85's Avatar
Drain it at 10k send it in to get an oil analysis done and then you can determine how long you can go on the drain intervals.
Right now I'm using Amsoil 5w30 'MTF synchromesh' shifts like butter and shifts better than the Redline MTL i had in before.
Old Aug 6, 2006 | 09:52 AM
meagainsttheworld's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">Drain it at 10k send it in to get an oil analysis done and then you can determine how long you can go on the drain intervals.
Right now I'm using Amsoil 5w30 'MTF synchromesh' shifts like butter and shifts better than the Redline MTL i had in before.</TD></TR></TABLE>
Where can you get that stuff?
Old Aug 6, 2006 | 10:47 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (meagainsttheworld)
at GM its 10$ a quart
Old Aug 6, 2006 | 10:49 AM
chrisw85's Avatar
You can get Amsoil 5w30 MTF synchromesh from your local amsoil distributor. I buy mine from a local store who carries amsoil.
or try contacting the guy here: http://cablespeed.com/~pabloma....html
Old Aug 7, 2006 | 12:40 PM
BLUE EH3's Avatar
Help we my pennies
bump
Old Aug 7, 2006 | 12:48 PM
Bense's Avatar
Default Re: (BLUE EH3)
we answered your question. Why are you bumping?
There is no magical answer. It's not like this fluid changes form over 6 months.
higher rpms = more work for brass synchros to match gear speed. Brass doesn't stick to in-case transmission magnet.
if you drove from miami to achorage, you'd stay in 5th gear for 95% of the time. This 3000 miles or whatever wouldn't put as much "strain" as 200 miles of tracking + romping around neighborhoods.
on my rebuilt trans I used 10w-30 for the first 500 miles. then drained it out and put another 10w-30 for another 150 miles. It's been 250-300 miles since that flush, I'll be putting 10w-30 in again for the next flush. And keep doing this until i stop seeing brass flakes from virgin synchros.
Old Aug 7, 2006 | 12:50 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (Bense)
Bense knows trannys
Old Aug 7, 2006 | 02:20 PM
slcivic's Avatar
GM sycomesh is a different vicosity then what honda recomends in the tranny, will using a higher vicosity result in less transmissions grind? sorry if this is tread jacking i was just always curious
Old Aug 7, 2006 | 02:42 PM
Bense's Avatar
Default Re: proper way to use GM sycomesh (slcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slcivic &raquo;</TD></TR><TR><TD CLASS="quote">GM sycomesh is a different vicosity then what honda recomends in the tranny, will using a higher vicosity result in less transmissions grind? sorry if this is tread jacking i was just always curious</TD></TR></TABLE>
excellent point. I've never thought about it. It's probably just a slightly thicker oil. Do you know what it's rated it by any chance?
Old Aug 7, 2006 | 03:00 PM
FalkenSiR's Avatar
Default Re: proper way to use GM sycomesh (Bense)
I always thought it seemed thinner, and I heard somewhere it was synthetic... any detailed info on this? 'I've been rocking it for 6k miles and I've been grinding some lately might put in some fresh synchromesh next oil change...
Old Aug 7, 2006 | 03:04 PM
E46Kid's Avatar
Default Re: proper way to use GM sycomesh (fast95eg8)
I thought this would be a diy you fooled me.
Old Aug 7, 2006 | 03:15 PM
Bense's Avatar
Default Re: proper way to use GM sycomesh (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">I thought this would be a diy you fooled me.</TD></TR></TABLE>
hahah
Old Aug 7, 2006 | 09:37 PM
slcivic's Avatar
i know that honda recomends 10w-30 or 10w-40 for the manual trans but i dont know what sycomesh is rated
Old Aug 7, 2006 | 09:50 PM
chrisw85's Avatar
most honda transmissions require a fluid with about 11cSt @ 100C, thats about what the Honda MTL/MTF is rated at when new, but the honda fluid is known to shear quite quickly judging by some of the oil analysis i've seen.
The Amsoil MTF is rated at about 9.4 cSt @ 100C.
Specialty Formulations has MTL-P which is rated at 11.3cSt @100C, so this might be a better choice. In a colder climate, get a slightly thinner fluid.
Old Aug 7, 2006 | 09:59 PM
Harryflores's Avatar
lololollolol... I'm not alone!
Old Aug 7, 2006 | 10:28 PM
strictly.business's Avatar
Banned
i use mobil1 5w30 for my tranny. today though, i put penzzoil 5w30 in it because i didnt want to spend $6 a quart for mobil1. with mobil1 5w30, i never noticed any problems.
Old Aug 7, 2006 | 11:06 PM
IT'S ME DAVID's Avatar
NooB
Default Re: (strictly.business)
well i just changed mmy tranny fluid this weekend.i used gm synchromesh friction modified.$1193 quart.bought three but needed only 2.before this when my car is rolling and i put it in 1st gear it would have a slight grind and 3rd will in high rpm's.after i installed this instantly it didnt grind in any gear whatsoever.and shifts are nice and smooth.
Old Aug 8, 2006 | 11:12 AM
EM199dcs's Avatar
so you should really change your tranny fluid at 30K intervals????
Old Aug 8, 2006 | 11:57 AM
delslowly93's Avatar
Default Re: proper way to use GM sycomesh (EM199dcs)
I just started using GM syncromesh and it got rid of my 3rd to 4th gear grind...but i was told that it should should be mixed with a 5w-30, any info on this?
Old Aug 8, 2006 | 01:21 PM
slcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM199dcs &raquo;</TD></TR><TR><TD CLASS="quote">so you should really change your tranny fluid at 30K intervals????</TD></TR></TABLE>
its recomended to do so every 30k miles or every 2 years, just like an oil change is recomended at 3k, but if you go over that mark you should be alright
Old Aug 8, 2006 | 01:27 PM
EM199dcs's Avatar
its recomended to do so every 30k miles or every 2 years, just like an oil change is recomended at 3k, but if you go over that mark you should be alright</TD></TR></TABLE>
I will change mine then what MTF is recomended?
